Results 1 to 13 of 16
    May 2012
    Grand Junction, CO
    Fireplace fubar!
    I mostly deal with commercial refer these days, but company asked me to go on a residential gas fireplace venting call. Amazing 6,000 sq ft home, only 4 years old, with 3 fireplaces all done like this. I don't think that's ok.
    Nov 2009
    Central Virginia
    I dont either....
    Sent from my SPH-D710 using Tapatalk 2
    ____________________________________________
    If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
    Jun 2011
    i've never done a fireplace. Whats wrong with this?
    Antelope,Ca
    Did they not finnish paying the builder? it looks like they never finnished the job.
    May 2012
    Grand Junction, CO
    Quote Originally Posted by RDorr92788 View Post
    Owner said builder ran out of money and they bought it and finished it.
    May 2012
    Grand Junction, CO
    Quote Originally Posted by timtanguay View Post
    Combustible material within inches of exhaust. Also cross ventilation
    May 2012
    Grand Junction, CO
    Also roof leak issues from rain and snow
    Jul 2000
    Northern Wisconsin
    Has all the signs of either one trade not knowing what they can or can't do when it comes to gas appliance vents or....... someone didn't like the looks of the ugly vents and threatened someone to either cover it up or else. And amazingly enough, the person doing the threatening is now out of money and couldn't finish it. Of course there is always the possibility that the homeowner did it themselves.
    Jun 2007
    Darby, PA
    Looks like a fail to me, wouldn't flush around here.
    Psalm 51:10, 12
    Apr 2010
    Ontario
    Looks like it has a top over the brick work. Otherwise rain will be pouring down in there.
    ENJOY THE RIDE
    Apr 2013
    I have installed fireplaces for the past 15 years and believe it or not I have come across this several times. After the tin top was installed on the chase the builder would change from a sided chase to a stucco or brick, the masons would remove the tin top and not tell anyone. Always amazed me what kind of damage a "little" water could do
    Jun 2009
    northern Ohio
    That chimney has no flashing around it either. Does the rain run down underneath the shingles?
    NE wisconsin
    How bout the osb exposed to the elements, getting wet melts the glue in that stuff pretty quick. If that was in wi, I wouldn't expect it to last more then one winter.
