Results 1 to 6 of 6
Threaded View
    Apr 2013
    Chicago
    Confused Gas Furnace sediment trap leaking oil...
    Hello
    The sediment trap (drip leg) that is connected to my natural gas pipe going into the furnace leaks oil once in a while. I tested for gas leaks with my leak detector and there are none nor do I smell any gas. Once in a while there is a wet oily spot on the concrete floor under the sediment trap. When this happens if I run my finger under the bottom cap of the sediment trap there is a clear oil on the bottom of the cap.
    This is a mystery does anyone have any clue as to why this is happening?
    Pete
