Results 1 to 6 of 6
    Jun 2009
    Albuquerque NM
    Honeywell Redesigned Prestige IAQ
    I was just wondering what you pros think about the new "Redesigned Prestige IAQ". My first thought is that they should have given it a better model designation, but maybe that's just me.
    It looks like the primary changes over the Prestige 2.0 are:
    1. Performance Logs - Keeps a history of heating and cooling performance. The performance log includes Minimum and Maximum Delta T, Minimum and Maximum Discharge Temperature, Minimum and Maximum Return Temperature, Minimum and Maximum Indoor Temperature/Humidity, Minimum and Maximum Outdoor Temperature/Humidity and Run Time. Quickly determine if the system is performing as expected and reduces service time on the job.
    2. It now has 4 sensor inputs (up from 2 on the Prestige 2.0). This is nice if you want to do return temp, discharge temp, a water drain alert, and something else like maybe a warning for air filter blockage.
    3. The thermostat form factor is now more like a "normal" size and shape - 4.5W x 3.5H x 0.88D (inches). From the photos, I'd say it doesn't look like a bump on the wall anymore.
    Saint Joseph, MI
    Shape and main screen remind me of the Carrier Infinity. Now if they just had a 3 wire communicating standard for all makes, you could use it as a controller rather than a thermostat.
    Feb 2013
    Aberdeen, SD
    I'm going to a class on it next week. One salesman said changes were just cosmetic. is there lots more to the redesign than looks?
    Doctorstone
    Feb 2013
    Aberdeen, SD
    Sorry, i didn't realize this was in the AOP section. I searched for the redesigned prestige, looking for a discussion amongst techs and didnt pay attention to this topic's categorization. Many apologies.
