Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 67
Thread: vacuum hose
    Oct 2010
    It's a $20 investment in a quality tool.
    If you're concerned over the quality of the hose or the brass, buy the ones that you are comfortable with.
    That said, YJ hoses are the only type of hose that I've ever had fail on me in use. I have had 2 of them swell, rupture and spray refrigerant while charging. A 1/4" and a 3/8" hose.
    Could just be statistics, I don't know about you but the majority of manifolds and hoses I've ever owned have been yellow jacket probably 3:1 yjthers
    Jan 2013
    I'd add to this to keep those hoses clean. Oil residue inside your hoses can affect evacuation as well, something that I've learned the hard way.
    Now, I've got a set of hoses that I have dedicated to evacuation and they do nothing else.
    The rest of my 3/8" hoses are dedicated to charging and refrigerant transfer.
    I know what you mean...my pump allows oil back up into my Appion 1/2" hoses.
    Either my blank off is screwed or the check valve gasket is shot.
    Quote Originally Posted by hvac5646 View Post
    Well, that wasn't exactly what I was referring to, but important nonetheless.
    Working on large equipment with large charges, using 3/8" hoses to charge, recover and transfer refrigerant is common and smart practice.
    It is also a good way to contaminate a good evacuation hose with oil.
    Nov 2011
    East Side
    did you know that non-rated vacuum hoses are mfg'd with tiny pin holes in them? You ain't gonna get a good vacuum and dehydrate the system if your sucking minute quantities of air thru these pin holes.
    check out the YJ catalog ....they detail hose construction. That is what the terms preamble and non-preamble refer to. Or do a Google search.
    I completely understand and agree.....BUT....My vacuum gauge isn't connected to the hoses when checking the system.....so their leak rate is a non issue.
    I've never had a problem pulling below 500microns with my standard hoses unless there's a leak, moisture, refrigerant trapped in oil somewhere, or my pump oil needs changed. Granted, I'm working on 50Ton or less systems.....If I were doing multi-hundred ton systems, I'd have 1/2" hoses, and a larger pump!.....oh, and i'd be making more money!!
    Cary, NC
    [QUOTE=jnsrose;15526681]
    The rest of my 3/8" hoses are dedicated to charging and refrigerant transfer.[/
    I also have 3/8" hoses dedicated to evacuation. Thinking about the 1/2" but really haven't done anything that big in a few months. Still trying to convince some guys on the new and improved evacuation procedures I have learned over the years from this site.
    I have found that most hose contamination with pump oil is due to overfilling the pump. Make sure that the oil level is at the right level with the pump running. Also using an evacuation tree such as the Yellow Jacket 93850 manifold insures that the vacuum hoses are well above the pump inlet which should keep the oil out of the hoses.
    Quote Originally Posted by gymguy View Post
    It can also be the result of transferring large quantities of oil-laden refrigerant.
    Of course, this isn't common in the residential/light commercial sector of our industry, but I do it quite frequently.
    Mar 2009
    Mid-Mo
    I have done the same thing. I have 2 3/8 hoses I use for vacuum, then one for charging and recovery.
    Feb 2012
    Toronto Canada
    do the 3/8 hoses speed up recovery That much?
    Mar 2009
    Mid-Mo
    Quote Originally Posted by OldSchoolMech View Post
    Absolutely. You need all the help you can get when you are pulling hundreds of pounds out of something.
    http://hvac-talk.com/vbb/showthread.php?t=1104411
    Have a look for yourself.
    Now, admittedly, he's using 1/2" hoses, here, but there have been guys who posted comparisons between 1/4", 3/8" and 1/2" hoses and it really is surprising how much faster the larger hoses pull.
    I won't evacuate with less than a 3/8" hose or three connected.
    Cary, NC
    Good point. That is why I reserve my high vacuum rated hoses for evacuation only.
    May 2013
    Louisville, Kentucky
    I recently purchased two NRP 1/2" heavy duty hoses. They have a 1/4 on one end and 3/8 on the other. They don't come with shraeder valve depressors. I put a brass tee with two 3/8 male flare fittings and a 1/2" male pipe thread going into my 8 cfm Yellow Jacket vacuum pump. I tried to eliminate as many possible leaking points as possible. I also purchased two Appion valve core removal tools. I intend to connect my vaccum guage to one of them. I haven't tried it out in this configuration yet but I think it will work well.
    Jun 2010
    Danbury Ct 1/2 hour from NYC
    I think the mastercool is a cheaper made product. I was just looking at the mastercool manifold and hoses at winair and I won't go with anything but yj. Everything I have in my cabinet is YJ. I do have a mastercool valve core remover and it works fine.
