    Dec 2006
    Compressor Start Problems
    I have a Heil 4-Ton heat pump. Once in a while the compressor will not start. It will try to start 10 -15 times with the overload taking it out each time. I am not sure but I don't think it's short cycling. The T-stat has a built in 3.5 min delay. Should I install a start kit? I replaced the dual capacitor thinking it may be weak but it still fails to start sometimes.
    Thanks for any help in advance.
    David
    Florida
    Quote Originally Posted by sc_dave View Post
    David
    Pick up the phone and get service for it. You've already replaced one part that was probably good. Next it will be a start kit, and the problem good very well still be there. It might not be equalising in the off cycle. Have a pro check it out....then if it does it their work should be warrantied and you're not throwing away money.
    Dec 2006
    Thanks for the info.
    I know the capacitor I replaced was weak because I tested it that is why I replaced it. However it did not cure the intermittent starting problem as I hoped it would.
    After I added a start kit the unit is starting smoother, faster and every time now.
    David
    Dec 2006
    Middle Tennessee
    what reading did you get when you tested it?
    Mar 2006
    cincinnati, ohio
    Quote Originally Posted by Airmechanical View Post
    And how many amps was it drawing at start up
    Knowledge comes with experience
