Results 1 to 8 of 8
    Apr 2013
    Emerson Furnace Motor Buzzing?
    Hello,
    I have a Thermo Pride forced air oil heating unit in my home and recently the blower motor has been acting up. Sometimes the blower motor fails to start when the furnace starts. It just makes a buzzing noise and after sometime will get hot to the touch.
    So i decided to take the motor apart and clean it with an air compressor. When i sprayed the compressed air into the motor a considerable amount of a reddish colored dust came out. Any idea what that may be? Also i took the start up switch out and noticed the copper contacts had soot on them and pitting was evident, which lead me to believe there was arching. I cleaned the switch with rubbing alcohol and slightly sanded the pitting with a real fine grit emory board. The copper cleaned up nicely with very minimal sanding. I thought for sure i had found the problem.
    Well, after about 5 days or so the motor was back to its funk, buzzing on start up and hot.
    Here's the kicker... after letting the motor cool it will usually start again...upon doing so, if i turn the thermostat from "auto fan" to "always on" the motor does not have any problems and is cool to the touch. I've been running it a week on the "always on" selection and the fan has no problems. When i turn the thermostat to "auto fan" after a couple of days of successfully cycling on and off that is when the motor returns to its funk.
    Any suggestions or ideas as to what the problem might be? I would like to fix the motor if at all possible. I would hate to replace the motor if that is not the problem. Any help is greatly appreciated.
    Emerson belt driven blower fan
    Model: SA55NXTE-841
    CAT: 841
    1/3 HP
    115 volts
    60 Hz
    5.4 Amps
    Regards,
    -Here in Philly
    Aug 2001
    Pavilion, NY
    The motor uses an internal centrifugal switch to aid in starting. That switch is defective. I see a new motor in your future. I would suggest that you have a full maintenance including carbon monoxide check on your unit as well.
    Jan 2012
    Broomall, PA
    Without testing with a meter, I would guess you have either a dead spot and/or a bad start winding. Either way you're probably gonna need a new blower motor.
    Apr 2013
    Quote Originally Posted by kangaroogod View Post
    Lets say it is the the centrifugal switch...anyway i can clean that up?
    Apr 2013
    Quote Originally Posted by STEVEusaPA View Post
    Any suggestions on a website where is can get a low cost decent motor? Ebay any good?
    Quote Originally Posted by Gianno View Post
    No no and noooooo.
    Aug 2001
    Pavilion, NY
    If you use the contractor locator map I am sure one of us can replace it, service it, and test the safety of the appliance. While I understand your willingness to save money we cannot go any further as this is not a DIY site.
    X2
