Results 1 to 13 of 21
    Jan 2005
    steeler nation
    how to charge 1.5 oz of 134a
    a wine cooler belonging to a friend of a friend of the owners showed up in the shop. this is a small cooler from a box store , maybe 20 bottle capacity. it no cool. i put a schrader in the process tube and started to play with it. how does one weigh in 1.5 oz of 134a. my electronic is + or - .5 oz. my plan is to charge it slowly until the suction line stops frosting and the case cools. anyone have any ideas?
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    We have freedom because somebody fought for it.
    We keep it because we are willing to fight for it.
    We lose it because we are not willing to fight for it.
    Jan 2011
    For critical charge units we used to use one of these. Probably too much to spend for the little job you have. I'd be tempted to do it your way.
    Jan 2005
    steeler nation
    Quote Originally Posted by KnewYork View Post
    the old dial a charge. i forgot all about those things. i used to have one that had a heater in it. i didnt know they still made them.
    IV IV IX
    Southeastern Pa
    You use a 4" hose with a little valve, on the end of your normal hose. Pull the vac.
    Now, close the little valve on the 4" hose. Fill the normal hose with refrigerant, jug on the scale. Zero the scale.
    Now, use the little valve on the short hose to meter in 1.5 oz. You can cap the short hose, and leave it there.
    Done.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Virginia
    put gauges on , vacuum down , hook up 134 bottle , purge line , open gauge valve and count out loud " one mississippi " , close valve , done.
    I think the smallest amount I recall using is like 7oz ... I use crt and purge the hose w/liquid to the crt. Zero the scale and charge to spec.
    Sent from my SGH-T999 using Tapatalk 2
    Nov 2010
    MN
    Disk you find the leak on this thing?
    Chicago, IL
    I usually charge these things until 15-20 PSI suction pressure. Always seems to work fine. If it has a static evaporator, you can feel it to get an idea of the charge level. usually about 3/4 to 7/8 of the evap will be cold and the remainder will be the superheating portion.
    Tampa Bay, FL.
    If you plan on checking the high side, don't forget to prefill that hose with liquid before you zero your scale. Otherwise you may take too much refrigerant with you when you disconnect the hose. Or better yet, use a "stubby" gauge.
    Jan 2005
    steeler nation
    thanks for the help. there obviously is a leak in this thing or i wouldnt have to add gas. i pressured with nitro at 100 psi overnight and didnt lose pressure. i leak tested with my h10 and didnt pick up anything in the compressor and condensor section. may be a leak in the evap but i am not going to tear this thing apart to find it. i already have more labor time in this thing than it is worth. i will give it another try tomorrow morning and use the suggestions that have been provided. i'm just not used to doing anything this small.
    IV IV IX
    Tampa Bay, FL.
    Quote Originally Posted by viceman View Post
    Sounds like you have a restriction instead of a leak.
    Jul 2012
    Western KY
    1.5oz total charge? May not be a leak. You probably lost 30-50% of you charge hooking your gauges up.
    Jan 2013
    Wisconsin
    Ummmm........use a charging cylinder for R134A. They come with directions and are made for critically charging in small amounts of refrigerant. Done.
