    Southeast, GA / Jacksonville, FL
    Gear reducer and motor
    Need to replace a gear assembly and motor on a Scotsman NME 1250 (i think)
    Looks pretty straight forward, but looks are usually deceiving.
    How hard is this to do.
    Thanks.
    st.petersburg,fl
    Quote Originally Posted by navyhydronics View Post
    Thanks.
    Very easy job, Hardest part is removing the auger, may need to use a puller tho.....
    Hope this helps
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
    Oct 2009
    Raleigh, NC
    Hard part normally is telling the customer how much it costs!
    st.petersburg,fl
    Quote Originally Posted by MicahWes View Post
    LMAO Too Right, Unless he lucks out and unit is still under warranty....other then that you are so right..
