Results 1 to 7 of 7
    Feb 2007
    Suffol County, Long Island, NY
    Heat Pump Ice Up
    Have a Lennox heat pump that ices up on me. Have replaced defrost board & checked out refg charge. There does not seem to be a sensor connected to board, and the wiring diagram is un-readable. Fan speed is OK, reversing valve is OK. Can not get it to go into defrost cycle by itself. Need advise & a wiring diagrtam for Lennox HP HP22-411-3P. Also does anyone know what manufacter handles parts for Air Pro heat pump, can not find any in my area.
    It has a defrost thermostat. It has two, one is for defrost(which is the one you want) and the other is for discharge temp. of compressor(don't mess with that one). Really can't go into much detail since I don't think it is allowed on here, but I know for a fact that is does have a thermostat.
    Believe none of what you hear and half of what you see.
    Feb 2007
    Thanks iwannahelp I will check that out, I wish I had wiring diagram.
    Oregon
    Quote Originally Posted by condojack View Post
    Have you tried searching? Lennox makes some of their technical installation manuals public. Go to the installation manual section vs the owners manual section.
    http://www.lennox.com/owners/archived-docs.asp
    Feb 2007
    Thanks Davefr for the info, will give them a try.
    Feb 2007
    Dubuque,Iowa
    As I recall on this unit it is strictly time based defrost. Defrosts according to jumper setting and terminates on thermostat.
    Feb 2007
    MSully thanks for the imput, will put it to good use.
