Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
    Sep 2012
    Hmm Performing Carbon Monoxide test for PM CHECK?
    I considered purchasing the ACM3 Fieldpiece adaptor for my HS26. I also looked into the SOX3 combustion analyzer for fieldpiece. Both are quite expensive, the SOX3 being close to $300-$400. If I was to perform a simple "Carbon Monoxide test" what would be the most cost effective and effective way of doing so. These are for routine PM checks.
    Apr 2012
    Cleveland
    Spend the extra money and buy a real analyzer. You can get a testo or Bacharach without the printer and not spend too much. It's a great investment.
    May 2011
    Western, KY
    Quote Originally Posted by Hvac216 View Post
    X2 and take a class to learn how and why to use it.
    Jul 2010
    nebraska
    x3.
    I'd forget about the Fieldpice combustion analyzer stuff, get a real combustion analyzer, and use it every time you are working on a combustion appliance, be it a repair or a PM.
    Some would say that you shouldn't even be working on combustion appliances if you don't have a combustion analyzer.
    May 2012
    Upper Michigan
    We have the fp one at work, I tried it once and it Didn't work so can't offer any advise on it but it does all the readings other than co that you need but it's hand pump. I would just invest in a real one
    Sep 2012
    Any thoughts on this device?
    http://www.sensorcon.com/products/kit-insp-co/
    link attached
    Apr 2012
    Cleveland
    http://www.trutechtools.com/testo310
    http://www.trutechtools.com/InTechHardCase
    Either one of these would be the way to go. The Bacharach is probably better. I use the testo 320 but the 310 doesn't have a removable probe which I don't like. Trust me, spend the extra money on a full analyzer. You WILL NOT regret it. If you add that with proper training you will make your money back in no time.
    Sep 2012
    appreciate the feedback can someone review the product I listed or know someone who have used it. When conducting a CO2 test, are you just finding out the levels of Oxygen and levels of CO (parts per million) to find out if the combustion is correct?
    Jul 2010
    nebraska
    Quote Originally Posted by sto2299001 View Post
    You're constantly measuring CO,O2,stack temp and draft for 10-15minutes,watching the readings to see if they are within range and stable . Do you really want to be hand pumping a bulb 9000 times a day? Double that if you change anything.
    Sep 2012
    would you happen to have instruction on performing this test? Don't you have use the bulb and pump it? Sorry I am still an apprentice.
    Considering purchasing this, performing this test is not mandatory, but just something extra.
    http://www.sensorcon.com/carbon-monoxide-detectors/
    Virginia
    What are your intentions with this piece of equipment?
    Do you want to be able to test a furnaces and to tell why the unit is producing excess levels of CO, and then effect the repairs based on that diagnosis, or do you just want to be able to tell the home owner their unit is producing excess CO (not knowing the reason), and just sell them a new furnace?
    If your answer is the first one I mentioned, then you need a combustion analyzer like the others have mentioned, and not a CO monitor, like the one you keep referencing.
    Buy one as a personal CO monitor if you really want one, as there have been many occasions where one will go off just walking into a home. Then it's your job to find out why, and most times, it's not the furnace.
    I applaud you for your wanting to be able to test furnaces properly by doing a combustion analysis, as so many furnaces are worked on without this important diagnostic tool.
    The key is having the correct tool, and training on how to use it.
    Sep 2012
    Quote Originally Posted by rundawg View Post
    The CO monitor I referenced comes with a pump to insert into flu pipe or furnace. If you place it accordingly the numbers alone should tell you if its running at "correct" levels. As you mentioned, it could go off when you walk into a customers home, but you should be able to narrow down where its coming from. How will the other devices referenced by other users tell me why the unit is producing excess levels. I just want to be able to tell the customer whether its running at suitable "healthy" levels or not. I want to be able to take down the levels to give customer piece of mind that its running at satisfactory levels.
