Results 1 to 13 of 20
Thread: hussman help
    May 2005
    hussman help
    i have a customer that has a hussman reachin, I'm sure its a ice merchandizer, i did a search and can't find anything on the system.
    model # is IS0671FG2 see #88K13682
    the case has no t-stat and a 8145-00 defrost timer that i think is doing the temp "control".
    i need a electrical cartoon..id like to bring it back to stock.
    help...
    Jul 2000
    Guayaquil, EC
    That's a Hussmann/Star model number, I believe.
    Husmann sold the Star division to Leer Mfg. back in 1991, so I suggest you try Leer for info.
    May 2005
    i punched in the model number and got nothing...its an old r12 system...
    What are you looking for?
    May 2005
    i want to rewire it, put in the original defrost timer and run it on a t-stat..
    Why not use the one you got? (Timer)
    Just wire your stat in series with #4
    From stat it energize the compressor and condenser.
    May 2005
    the 8145-00 doesn't work, and its expensive to replace..some one made a birds nest of the wiring,
    and id like to get it back to original...
    What timer are u going to put in there?
    The newer unit uses the domestic timer
    May 2005
    this is why I'm looking for a cartoon of the wiring..
    I can tell you that I used to work on a lot of the Haussmann and star ice merchandiser
    They all used to use the paragon timers
    That r12 box came with paragon timers
    The new leers come with Mickey Mouse domestic timer
    I can draw you the schematic if you want
    You just need to tell me if the the unit u got a 2 wire termination
    Or not.
    The schematic is the basic freezer schematic.
    If you email all the component you have in there I can email you the ladder schematic
    May 2005
    thanks, but I'm gona call hussman in the morning, its like pulling teeth with them..
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by primmers View Post
    Call Leer.......>>>>>> 1-800-766-5337
