Results 1 to 12 of 12
    Mar 2013
    Oklahoma
    Carrier GXN Air cooled -EXV promblems
    Having promblems with EXV valve opening , unit shutting down on loss of refrigerant flow.Motor on valve is very noisey.Motor seems to drive open and closed in self test.Anyone else had simular problems. Thanks
    Dubai
    Quote Originally Posted by kevans1993 View Post
    Please follow the primary steps to troubleshoot the exv trouble
    1. Check the exv coil resistant
    2. Check the liquid level
    3. Check the thermistors.
    4. Check the exv driver board.
    Or put in test mode and try to open 100%...............then post the status.
    East of big city prices.
    Can you physically see the motor drive open and close?
    Jul 2012
    Western KY
    Have seen what looks like cigarett tar, assume its POE after being cooked, coat the inside of the economizers. Kind of sticky and gums up the works.
    Mar 2013
    Oklahoma
    Upon recheck motor opens and closes.When compressor starts makes loud noise then shuts down on code 9999 loss of refrigerant flow .
    So the next step would be to add some refrigerant ?
    What's the plan ?
    Apr 2009
    Columbus,Ohio
    What is your pressures on refrigerant side when it goes into alarm.
    Jul 2012
    Western KY
    Figure it out?
    Probably not he's going to keep pumping her down until the compressor dies.
    Quote Originally Posted by Tommy knocker View Post
    Figure it out?
    Jul 2012
    Western KY
    Quote Originally Posted by Dallas Duster View Post
    I hate that machine myself. It's a PITA to keep clean.
    It may be a maintence nightmare for some but it's pretty solid.
    Jul 2012
    Western KY
    Ya. Anyone over 6' or 180lbs won't like facing those inner coils.
