Results 1 to 8 of 8
    Contactor Fried On Heat Pump
    I have a Ruud heat pump about a year and a half old that just stopped working. The metal contact points on the contactor have obviously been getting very hot, melted some of the insulation on the line wire. What would be the cause of this?
    Oct 2002
    Plano, TX
    Bad or loose connection. Nothing to get alarmed about
    Northeast Ohio
    Improperly sized feed conductor, over amping compressor, poor connections, low line voltage. Have it checked by a licensed contractor before real (read EXPENSIVE) damage is done.
    DEM
    Quote Originally Posted by heaterman View Post
    To add a few more, unit in confined causing pressure switch to cycle, dirty coil etc.
    Thanks everyone. I'll get it checked out. I think the biggest problem is the contactor says "Made in China" on it.
    Oct 2002
    Plano, TX
    I thing "lug not tightened by American" more possible
    Good one, tjb
    Sent from my HTC VLE_U using Tapatalk 2
    Good one, tjb
    X2
