Results 1 to 11 of 11
    Mar 2013
    Converting from baseboard to ducts and heat pump Lennox XP14 or Trane XR 13
    These two estimates are the best complete with ducts and locally recommended. The trane dealer recommends a 3 ton, the lennox dealer says it will cycle on and off too much.
    House is in Virginia 3000 sq ft but 2 zones, 2 stories. both dealers recommended, price about even which is the better setup?
    Installer One
    Install 3 Ton XR13 Heat Pump with veriable speed air handler for 1st floor and basement(14.50 Seer,12.00 EER, 9.0 HSPF)
    Qty. 1- Trane 4TWR3036 - Heat Pump
    Qty. 1 TAM7AOC36 - Air Handler
    Qty. 1- BAYEVABC15BK - Heater
    Install 1 ½ Ton XR13 Heat Pump for 2nd floor14.5 ,12, 8.2
    Qty. 1- Trane Heat Pump: 4TWR3018
    Qty. 1- Trane Air Handler: TAM4A0A18
    Qty. 1- Heater: BAYEAAC08BK
    Installer 2
    OPTION 1) 2 Lennox 15 Seer Elite XP14-018 Heat Pump Outdoor Unit
    2 Lennox Model # CBX27UH-018 Air Handler Indoor Unit
    2 Lennox Model # ECB29-05 KW Strip Heater
    Virginia
    a detailed manual j load calculation will determin what you really need .here in virginia it is better to go a little big on the cooling so you heat strips do not run all the time n heating season
    Go Trump
    Saint Joseph, MI
    Quote Originally Posted by catmanacman View Post
    I'm not sure i adhere with that. VA is more a a southern climate than a mid Atlantic. Its pretty balanced and over sizing, especially upstairs will cause humidity issues on summer. I could are using a 2 ton 2 stage downstairs. Upstairs will probably rarely us strips anyway. On that climate with stack effect, net heat loads and gain will be about the same upstairs.
    A load calculations I'd best....but i like the way #2 is thinking.
    Sent from my DROID RAZR using Tapatalk 2
    Jul 2000
    Northern Wisconsin
    With the minimal information that you've supplied it's impossible to tell. It's like going to a medical bulletin board and asking: I'm 50 years old and have a heart condition, one doctor recommends I have open heart surgery and the other is recommending shunts. Which is better?
    If they both did a heating and cooling load calculation then they both should be able to show you the numbers that proves their case for their recommended system. With out that information they're guessing. Are you willing to spend X amount of $'s on someone's guess? Have them show you the proof that what they're recommending will "in their expert opinion" be the best for your situation. With heat pumps and electric back up I'd suggest you have them show you what they "think" will be your costs of operation in your area of the country. That would be another factor to weigh when making your decision.
    Good Luck.
    PS: Being a hydronics person I cringe whenever I see someone taking out hot water heat and replacing it with forced air heat.... especially if they've lived with it and are used to the comfort it provides.
    Mar 2013
    It's electric baseboard and no a/c currently. I'm going to have another estimate with load calculation done Monday. These others are just guesses but I can always ask for changes to estimates if I know what direction to go.
    Saint Joseph, MI
    Quote Originally Posted by firecontrol View Post
    I thought that at first too. But then I realized he never mentioned oil and I figured he was talking about electric baseboards. the only think worse is an electric furnace. At least baseboards create radiant heat, can't leak air ot unconditoned spaces and can be zoned. But in VA, a heat pump should use about 1/3 of the energy seasonally than baseboards plus you gain AC.
    Aug 2008
    Booneville, Mississippi, United States
    Lennox all the way. Been installing ams std, had lots of problems with tam7 control failurea. Swapped to lennox and life is so much better.
    Jun 2010
    Philadelphia PA
    You didn't say you were going to abandon your hot water system.
    I would suggest you consider a hybrid approach where you would extend your hot water system to HW coils in the air handlers so that the moderate temps of Spring and fall are covered with an air system and then with an outdoor stat, use the hydronis as stage 2 heating. If your system works now, why throw it out? Your outdoor set point ( balance point should be the temp where the heat pump needs to begin defrost cycles ( ask your contractors to explain
    Jun 2010
    Philadelphia PA
    Whoops, elec baseboard, forget hybrid but it doses raise the interesting question of using existing vs backup resistance heat
    Need to read and not scan
    SW FL
    VA = Mid Atlantic = only 1,350 CDD
    http://www.climate-zone.com/climate/...inia/richmond/
    Designer Dan
    SW FL
    How MANY load calcs have you accumulated?
    U get 1 or 2 every month .. they are called Utility Bill $
    Designer Dan
