Results 14 to 22 of 22
    Oct 2010
    Quote Originally Posted by rayr View Post
    Not making excuses for the install, but if the roof is pitched, it is a pita cuz you cannot buy factory curbs with the specific pitch. Have to be made in the shop and welded. We have to make 4 in a couple of weeks for 10 ton units.
    Or you could just build it up level with lumber then set the factory curb
    Aug 2012
    Palmyra, Missouri, United States
    needs shoved onto curb. you can see it is not all the way down.
    Amarillo by mornin'
    Just take the filter door off. Looks like you could stick your hand between the unit and the curb in there!!!
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Oct 2007
    Milwaukee,WI
    Probably didn't unscrew the fork pockets (like a lot of tranes have) before setting it on the curb. Sometimes it helps to read the install manual first
    ___________________________
    Chicago is an indian word for stinky!!!!!!
    -supertek65
    Aug 2012
    Antelope,Ca
    You cant see the other side but this is a side discharge unit.
    Dec 2010
    Woodbridge Twp, NJ
    Quote Originally Posted by RDorr92788 View Post
    Then that shove is gonna be a bit noisier than you expected.
    Every customer you take for granted today will be someone else's tomorrow.
    Dec 2012
    Lowell,MA
    looks small enough to get a couple guys and lift 1/2 inch or so and move over to sit on curb properly
    Jun 2006
    SW MO.
    Quote Originally Posted by 71CHOPS View Post
    looks like it isn't sitting on the curb correctly.
    Ditto.
    Apr 2013
    We have an easy fix for this type of situation, his name is big joe.
