Results 14 to 26 of 27
    Central VA
    Hopefully that wasn't from the factory
    May 2012
    Philadelphia
    This unit was only a year old. Panel was missing screw and flapping in wind. The compressor was fragged, probably from the constant jogging when terminals arced.
    As for the warranty ??, We did not install it, and the unit was not registered by a contractor so supplier said NO.
    Nordyne HP, comes with 6 inch bugs(pre-crimped, stranded wire). WE, nut them to solid stat wire then connect to terminals. May have been a goodman, I can't remember.
    Mar 2001
    Ilwaco, Washington
    I use these, or a short piece of stranded wire with a crimp connector on the board and then wire nutted to the tstat cable.
    www.grainger screw disconnect
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Feb 2011
    Orange County, in a Galaxy far far away...
    jebus h christopher
    You cannot cheat an honest man. But that doesn't stop people trying!
    Dec 2003
    Citrus County, Florida
    You complain just because the guy ran out of solder?
    Doug
    SC
    Yep.
    That's what I thought the hole was for... that sort of connection is actually superior to most others... if you add solder.
    May 2013
    Los Angeles, California
    He forgot his wire wrapping tool that day?
    Apr 2006
    South West Ohio
    I have done that in a pinch to get a unit running, But never left it like that.
    NJ
    Whats a sta-con?
    May 2013
    Nov 2011
    St. Louis
    I didn't know what sta-con meant either when I saw PHM use the term on another thread. Stay Connected?
    Just proves once again that there are no stupid questions - but if you are afraid to ask just stick around and someone will ask one...
    Mar 2001
    Ilwaco, Washington
    A Stakon is like a Jacuzzi. All hot tubs aren't Jacuzzis but all Jacuzzis are hot tubs according to Sheldon Cooper. All Stakons (brand name) are wire terminals, but not all wire terminals are Stakons.
    Feb 2013
    Cary NC
    you lost me at spade connector.
