Results 1 to 11 of 11
Thread: thermostat
    winston salem
    Smile thermostat
    I do some residential maintenance tune up's I get people ask me to calibrate their thermostat, does anybody do this, a guy asked me to look at his thermostat I pull off the cover to tstat looked at it making sure it didnt have a bunch off dust kind of laughded to myself and then said its fine.
    does anybody adjust the heating anticipator sometimes, i am kind of unclear how to do so, it has been awhile.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by NCSteve View Post
    on the older style non digital stats you can check inside temp. with a digital
    thermometer, then calibrate the inside temp reading with a little screwdriver
    just pop the cover off the stat and look behind the cover and you
    will see the adjuster screw!
    oh ya, you can also adjust the heat anticipator!
    you are supposed to take the amp draw between R and W to set the anticipator. Or you could cheat and just look at the gas valve's amp draw rating.
    O.K. how many of the Heating and Cooling God's are going to totally disagree with what I have just wrote?
    leland nc
    i always check the anticapator setting on the mercury stats and on some digital stats
    with 80 and 90 percent furnaces it is important to have it set correctly to avoid short cylcing of the furnace
    amazing how many are not set correctly and left at the factorie setting
    Mar 2006
    cincinnati, ohio
    iwannahelp how long have you been in the trade and do you think everytime you post somebodys gonna question it
    Knowledge comes with experience
    nickellhead, I've been in the trade ...too long.....haha(if ya know what I mean)
    I know a lot of people on here think that they are the greatest at HVAC and no matter what anyone says those people will always have a better way
    than you. That is just how it goes.
    Mar 2006
    cincinnati, ohio
    Some poeple are shovanists but the majority like to gain usefull knowledge from others
    Western Suburbs of Philly
    Quote Originally Posted by iwannahelp View Post
    That's how you set the anticipator alright, but I totally disagree with that last part
    South-Western, ON, CAN
    yeah iwannahelp,
    usually the amp draw for the heat anticipator is on gas valve (if not there, but you know the model of the combo-gas valve check on the manufacturer's website to see heat ant. settings. Honeywell or White Rogers are the two largest GV manu's)
    to get a accurate reading try spinning a coil of wire (ten twists works best, the divide by ten) and running it in series with the heat anticipator, but most new meters are pretty accurate.
    later
    Mn the state where absolutey nothing is allowed
    on mercury stats id always check the amp draw,,the gas valve may not be the only load the anticipator sees.also be sure to wait 'till the fan comes on in case of a heat assist fan control
    bowie md
    with calibration I also level the thermastat
