Results 14 to 19 of 19
    Southold, NY
    Quote Originally Posted by small change View Post
    The ecm motor will fail if the filter isn't maintained regularly and properly
    And where did you get this information?
    Mar 2013
    specify what model number/brand of condensate pump to be installed instead of heavy duty (nitpicking)
    Refrigerant piping Usually equals Lineset and in a lineset the suction line comes preinsulated liquid line does not. is this the case?
    Raintight disconnect box....no mention of a fusible disconnect which it should be.
    No mention of Permit...permit costs costs or the pulling of a permit with the local jurisdiction.
    Why an 80% why not a 90%? Where are you located?
    Thanks for feedback small change. Is 90% more edficient? Located in NJ.
    Sep 2003
    Perhaps I should have said Scheduled, Regular maintenance on your furnace will keep it running
    efficiently for a long time.
    But I have been running into a spate of ecm motors (modules) lately that have failed due to poor maintenance practices and the direct correlation was a failure to change the filter media for sometimes years at a time.
    I suppose the same could be said for any furnace/motor combination with an extremely dirty filter but just something I have run into lately.
    Sep 2003
    Yes 90% furnace is more efficient than an 80% effiicent.
    Ask any contractor to quote you both if he is just quoting you an 80%
    Tallahassee, FL
    How big is your house and how did they determine what size you needed. The posted sizes would typically be a 3000+ sq ft home.
    Mar 2013
    House is about 2400 sq ft (1200 sq ft per floor).
    Also have finished attic which will not be hvac-equipped.
    Live in NJ, gets cold in winter and quite humid an summer.
Tags for this Thread
