Results 1 to 13 of 21
    Dec 2012
    columbus, OH
    Rebuilding a vacum pump
    I tore down a robinair 5cfm pump to see why motor kicking out on OL. Found the spring that modulates first stage vane was tangled up and broke. So I called robinair tech support and was informed they cannot sell internal components. Amy ideas on how i could obtain this spring or how spring are sized? TIAImageUploadedByTapatalk 21364410684.010442.jpg ImageUploadedByTapatalk 21364410709.436544.jpg
    Anytown USA
    Moved to Tools and Test equipment forum.
    Dec 2012
    columbus, OH
    Thank you for the link, I dont think I have the means to accurately size the spring other than length and width. I would assume compression strenth is important, if it was not the same as the other spring it would set the blades off balance. It still sucks scraping a perfectly good pump over one little spring.
    Anytown USA
    Order a few different types and sizes of springs. Give it a shot, nothing to lose right?
    Athens, Ohio
    They say "cannot sell" which means "WON"T sell." That would be the last of their products I would buy.
    Mar 2001
    Ilwaco, Washington
    Will they sell the whole module?
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Mar 2013
    looks like a spring in a ball point pen.
    Dec 2012
    columbus, OH
    Quote Originally Posted by uniservice View Post
    Yes they will sell the whole module no problem
    Dec 2012
    columbus, OH
    Quote Originally Posted by y7turbo View Post
    Thats a good idea, im going to try it. I will post back how it turns out.
    Dec 2012
    columbus, OH
    Quote Originally Posted by jtk910 View Post
    It is wound more tight and a little thinner.
    Dec 2012
    columbus, OH
    Your article is refering to spring the season?
    They suck. My vanes wore out after a year and it was barely used during that year and ofcourse they wont sell those either. I lightly sanded them and figured I was going to screw it up but it didnt work anyway so big deal. Turns out it works better than ever now. If you hold the vane against something flat you can see that it is uneven and if you carefully sand them they will work again. Maybe I just got lucky. I also found a vane manufacturer online that said he could duplicate them if I sent the old vanes to him and the price was very reasonable.
