Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 40
  1. #27
    Jul 2012
    Western KY
    Quote Originally Posted by SEIDexter View Post
    Am I reading your statement incorrectly or are your two last sentences contradicting each other?
    I probably typed it wrong. What I I mean is thinking all drains have to be ran to gutter or roof drain is absurd. However if you want to do that there is nothing wrong with that, well except maybe getting a slum lord to pay for it.
  2. #28
    Jun 2011
    Quote Originally Posted by RDorr92788 View Post
    In my area they will nail us if we don't drain off the roof.it also has to drain into dirt and cannot cross concrete. several times we had to drill thru concrete to pass.
    Seriously? This is crazy. What's wrong with the p-trap just dumping on to the roof? Seems like an absurd amount of waste. What is the rational behind this?
  3. #29
    Aug 2012
    Antelope,Ca
    I'm not sure why off the roof, but the concrete is because they say it causes slippery conditions
  4. #30
    Jun 2011
    That is still silly...if it dumps on to the roof, then it'll make its way to the roof drain system. Ah well, who knew. I'm thankful I don't have to worry about that in the frozen north.
  5. #31
    Aug 2012
    Antelope,Ca
    my coworker tried arguing that rainspouts cross the concrete. they didnt care
  6. #32
    Jun 2011
    I guess AC run-off is magically more hazardous and slippery than plain-old roof run-off. Must be all those nasty HFC and POE oils that leak out of the system.
  7. #33
    Aug 2012
    Antelope,Ca
    Quote Originally Posted by timtanguay View Post
    HaHa
  8. #34
    Oct 2008
    Quote Originally Posted by Freightshaker View Post
    You must be getting old. I do the electric slide through condensate slime. It helps me go unit to unit faster to tape up capacitors, jam cig butts in contactors, and check suction lines for beer can cold while simultaneously unhooking economizers.
    I've never done that "cigarette butts jammed in contactors" thing. Can you elaborate on that? I might learn a new trick today...
  9. #35
    Oct 2008
    Quote Originally Posted by hvac wiz 79 View Post
    I was once told by a co-worker about a guy who would remove the trap and drink the water out of it.
    I'm sure that "drink of water" required some mild chewing - about like what's required for over-cooked boiled okra.
  10. #36
    SC
    That trap has been reused. Either the roofer did it, or the unit has been replaced and the "installer" used the old trap.
    Look at the tar stripe on the bottom of the P... this trap was installed properly at some point.
  11. #37
    Dec 2006
    DFW Texas
    I often see that too where they go through a lot of trouble and pvc material of piping an elaborate draining system on the roof to expel the water into a rain drain or close to it. I often scratch my head of what's the point?
    A lot of times this is done to prevent the growth of plants on a roof that is tar and gravel or just has low spots that hold water. I can't tell you how many small trees I have found growing next to units that were not drained properly and just let the water fall on the roof. The roots will find their way through the roofing material.
  12. #38
    Jun 2012
    Quote Originally Posted by ECtofix View Post
    If you have a pesky safety dropping out a contactor, just jam one in the hole so it won't shut off. Remember to be safe
  13. #39
    Apr 2013
    One of the dumbest things I've seen was at a school 20+ rtu's with p traps that just dropped into pans placed underneath them which eventually overflow onto the roof anyway.
