Results 1 to 7 of 7
    Feb 2013
    wiring a humidity sensor switch into an existing on / off switch bathroom fan
    i would like to install a humidity sensor switch into our existing bathroom fan set up which just has an on/off switch. i still want the on / off switch to work for the fan, but I also want the humidity sensor to turn on the fan if the humidity gets too high. currently there is only the 3 wires from the switch running to the fan etc.
    do i need to run a wire from before the on / off switch (essentially bi-passing the switch) to the new humidity switch and then the wire from the humidity switch back into the wire that runs to the fan.
    that way there is still only one wire taking power to the fan, but either of the switchs can turn on to allow the power to flow.
    does that make sense?
    thanks
    Mar 2001
    Ilwaco, Washington
    be careful matching line voltage to a dehumidistat. Most all I've seen are low voltage.
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Feb 2013
    The installation instructions say for 24v or 120v installations
    Jul 2000
    Northern Wisconsin
    How old is the fan? There are units on the market that have built into them just what you're looking to do. They turn on with a spike in humidity from say a shower and then once the shower is over they run for another 20 minutes. To install a simple humidity control the fan would run anytime the set humidity level was exceeded...... this could be on a humid day in the winter with no one being in the bathroom. Also, when the existing fan did finally need replacing, if it were replaced with a "smart" fan, what you did would be no longer needed. Spend the right money now instead of later?
    As for how to do what you're asking, we can not supply that kind of information because it is considered DIY and that is against site rules to do.
    Madison, WI/Cape Coral, FL
    The concept of operating a bath fan on high humidity does not work when the outdoor dew points are +60^F. You will end up with a fan operating 24/7 and a damp house. Better option is an extend run timer as part of the bath on/off control.
    Regards TB
    Athens, Ohio
    I attended a seminar which included information on the new Panasonic vent fans. Some of them have humidity control built in. You can wire them without a switch, just 120 volts to the fan. I've been considering one for our house.
    Just replace the existing switch with a switch that has a timer feature.
    You are only concerned with the humidity created with bathroom use, so run the unit for an hour after the last use and it shuts off automatically. Time is dependent on who you talk to.
    For while house dehumidification you want other things.
Tags for this Thread
