Results 1 to 13 of 23
    Apr 2004
    MN
    Heat pump filter/drier question
    If a heat pump utilizes a single capillary tube for metering to both coils, would 2 filter/driers be required? I would assume you would need one at each end of the cap tube with a bypass on each filter/drier.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Tallahassee, FL
    Wouldst it be impossible to size the single cap tube for proper pressure in heat and cool?
    Mar 2013
    Joplin,Missouri
    One biflow drier in the liquid line should be all you need
    Dec 2003
    Citrus County, Florida
    Quote Originally Posted by SBKold View Post
    I would tend to agree with you because you'd be using less of a charge in heat mode.
    Doug
    Apr 2004
    MN
    Here's the deal. I'm designing a heat pump that has a manually operated valves for the RV. Trying to keep it as simple and inexpensive (value engineering) as possible. I was thinking if I used 2 coils of the same size with a cap tube in between them it would make the concept of reverse flow easy to understand. It will be a fractional horsepower compressor from a Coke machine. Maybe I should just use 2 cap tubes, each with a filter/drier and check valves?
    Yes u would need two driers if u only have one cap tube
    But single cap tube theory will not work
    Cause indoor and out door don't have the same load.
    I'm not sure where would u put ur manual change ove reversing valve?
    Fractional HP will not work
    Not enough btu capacity
    Feb 2013
    Florida
    With a single cap tube(which I don't think it would be possible), you would have to use a bi-flow filter as their wouldn't be any check valves and you would only have one path for the liquid
    Apr 2004
    MN
    Shaka, all I'm trying to accomplish with this "test" model is theory reinforcement. A fractional hp compressor will do absolutely fine. All I'm hoping for is a cold coil and a warm coil. Not really desiring great amounts of heat transfer. I did this drawing in Paint. Let's see if it will work. By closing one of the valves in the discharge line and one of the valves in the suction line, I should be able to manually control the direction of flow.
    Name:  Manual heat pump.png
    Last edited by doc havoc; 03-27-2013 at 05:24 PM. Reason: Changed diagram to reflect closed valves.
    Tallahassee, FL
    looks good to me doc.
    put 2 biflow driers on either side of tube or just even strainers since its just a model.
    My bad
    It's a learning apparatus
    In that case it looks good
    Why not just use a real RV
    So they can understand it on the bench.
    If u ask me those shut off valve cost more that RV.
    Jul 2009
    Columbia, MD
    Just use one drier and add it onto discharge right after compressor. York did it for years.
    Aug 2009
    Maine
    Sort of like a small condensing unit and evap. I always tell the customer to think of a window AC turns around.
    Quote Originally Posted by doc havoc View Post
    Tallahassee, FL
    Quote Originally Posted by gravity View Post
    Just make sure its a quality solid core one from sporlan though!
    Not a bad idea though....then just use a couple strainers at the cap tube. Guess the only downside is the strainers will release any debris whenever it switches.
