Results 1 to 7 of 7
    Feb 2011
    Toronto Ontario
    Chiller start ups
    Hey guys, I was just wondering what it is you all do for chiller start ups just before the cooling season start. Thanks!
    ottawa canada
    Screw , scroll , recip , centrifugal , air cooled, water cooled .......Give us a clue at least !!!
    Jul 2012
    Western KY
    Depends. A lot of process chillers run year round so its just another quarterly PM. I like to brush tubes in the spring. Follow the manufacturers maint guidelines. If you have towers this is a good time to get them slicked up as well.
    Apr 2009
    Columbus,Ohio
    On water cooled chillers, I change oil filter, Refrigerant filters, then leak test refrigerant side of chiller, go through starter tighten up all electrical then vacuum and clean all dust, dirt and etc. out. Calibrate controls. Brush condenser tubes, clean cooling tower clean strainer.
    if you guys are doing this during the spring start up...what are you doing during the winter shutdowns? i perform all of these types of maintenance during the winter so that any issues found can be taken care of before the spring.
    Jul 2012
    Western KY
    Quote Originally Posted by jayguy View Post
    Alot of the same stuff. I also hit all the motors, check all bearings, go through the starters. Like you said, fish for winter work. Most of the machines I take care of are process so there isn't a real shut down for the season.
    Feb 2011
    OH
    lets have fun clean and rod condensers edycurent and inspect tubes cooling tower maint mudy but good money in winter 'along with strainers and controlls ; cooliing tower s some need oil change in gear box' moter bearings pumps vibration analysis .having fun yet .on some comps might be time for upper and lower end maint . amonia water jackets get plugged . york yt have cooling coil and and that cools inverter needs checked .purge pump.
