Results 1 to 13 of 23
    Apr 2012
    Edmond, Ok
    Carrier or Trane
    Which is better? Carrier or Trane?
    Feb 2013
    Lamar, SC
    The one that is sized right, installed correctly and properly maintained.
    Dec 2011
    North Texas
    X2.
    Jul 2011
    East coast USA
    well, I use a lot of carrier units. last year i installed a large job. all units came form Mexico. had just a few problems.. There are a few things i don like about the new carriers and it pisses me off... Unless you get the more expensive ones.. all the panels are screwed on using these plastic inserts to screw too... during install, Electricians, mechanical guys and balance guys stripped almost half of the the plastic holders...now i have to worry about covers flying off. So now i'm running around zip screwing them.
    The other thing i noticed, Carrier is using carbon molded pulleys on the fan not motor just the fan..So far no issues..Just thought that was interesting. The bottom line, on the commercial grade or budget grade they really cheapened the quality anywhere they could. Also, i needed a factory part, and it took forever to get...
    I starting to look at Trane more...not sure how much better they are in quality ..looks like everyone is cutting where they can.
    OK that was commercial units...The same goes for Residential, but i will say, Carrier and Trane make different grades each cost a bit more. when pricing out the job ask your rep what the differences are..Sometimes he may not know..But sometimes its like getting a plastic bushing instead of a brass one..or heaver gauge metal, sound deadening etc...
    Feb 2013
    Summerville SC
    Quote Originally Posted by jmsmars1 View Post
    this answer reminds me of the movie forrest gump where his sergeant asks him what his purpose in the military is.
    now my company is authorized Bryant and Trane dealers. I install and work on a lot of carrier/Bryant systems along with Tranes. I like both about equally. They are both high quality reliable systems as long as they are installed correctly as jmsmars1 said.
    "only 2 tools any man needs is wd40 and duct tape. if it moves and it shouldn't use the duct tape. if it doesn't move and should, use the wd40" -unknown
    Mar 2013
    NJ
    Depends on a couple different factors not just the brand. How it's installed, how it's matched up, efficiency, and how it's serviced. There's other brands out there that are less expensive and will run just as good.
    Virginia
    kind of like comparing a caddy to a lincoln
    Feb 2013
    Lamar, SC
    Quote Originally Posted by Snapperhead View Post
    Caddy is the best
    "If you've eliminated all other possibilities whatever remains must be the truth."
    Mar 2013
    Joplin,Missouri
    I choose none of the above im a lennox man all the way
    Largo
    Look at My Profile Pic!!
    Aug 2012
    Caddy gm
    lincoln ford
    in this case ahhhh they both suck.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Jun 2001
    Shop by features and construction detail, not by brand. Of course install quality trumps all.
    Jul 2009
    Columbia, MD
    Trane
