Page 3 of 3 FirstFirst 123
Results 27 to 38 of 38
  1. #27
    Jan 2013
    HOW ABOUT THIS FO AN IDEA
    Quote Originally Posted by Moparmyway View Post
    Got the new Blue Vac to use today, as well as the new sensor for the YJ setup. Both were within50 microns of each other the entire way from atmospheric down to 150 microns !
    I love the Blue Vac's programmable alarm, I set mine so that after 15 minutes @ 250 microns or less, it starts chirping ...................... AWESOME !!!!!
    HERE'S AN IDEA:
    BluVac wireless compatibility with FP and Testo.
  2. #28
    May 2010
    Canada
    Hey Joey,
    Every now and then my Bluvac will act up a bit after I disconnect it from a vacuum. The other day it took around 20sec to read above 25000microns. I cleaned the sensor and threw it in the freezer but it still does this once in a while. I'm wondering if maybe it's the Nylog. The performance of the Bluvac is not affected at all ( I compared it to my other Bluvac) and the readings were within 10% of each other.
    Any suggestion?
  3. #29
    Atlanta GA area
    If I cant clean it, and I have to purchase another sensor, I am gunna get a Blue Vac instead !!!!!!!!!
    If you decide you do not want that YJ... send me a PM... maybe we can cut a deal.
    GA-HVAC-Tech
  4. #30
    May 2011
    New York
    Quote Originally Posted by ga-hvac-tech View Post
    Gunna keep them both ............ since I was able to source the vacuume sensor for under $60, the YJ is back in service, and I love the BV, so they are both keepers !
    Extended dehydration is the key
  5. #31
    Aug 2010
    Coral Springs, Florida
    Quote Originally Posted by eddiegoodfellar View Post
    This is caused by residual refrigerant gas in the sensor port. Next time you see this happen, gently blow a little air into the port, and you'll see the gauge go to Hi-P immediately.
    This is not an effect specific to the BluVac. All micron gauges using thermal conductivity to measure vacuum will be affected similarly (and equally!). Since the BluVac responds so much faster than other gauges, the effect is more apparent.
  6. #32
    May 2010
    Canada
    Quote Originally Posted by joeyd View Post
    Thank you.
  7. #33
    May 2011
    New York
    Hi Joeyd,
    I MUST admit, the more I use your Blue Vac, the more I like it !!!!
    I am learning to trust it as I do my YJ setup, and one of my vac pumps pulled down to 1.5 microns with 10 ' of 1/4" copper tubing attached.
    Great product @ a great price............ I can get 4 BV's for another YJ setup ............... am gunna order a few more BV's in the next few months !!!!
  8. #34
    May 2011
    New York
    Just an update ....... I now have 6 Blue-vacs - and dont know where I left my YJ. Its still around, just havent reached for it since the BV's are ssooo easy !!!!!!
  9. #35
    Warren, MI
    You have six BluVacs?? You have a need for six setups running at the same time?
    Bill
  10. #36
    May 2011
    New York
    Actually - I think I need another 1 or 2.
    But yeah, I am using all 6 at one time. Right now 3 of them are on one chiller (Monmoth) with 3 seperate systems, and I am about ready (tomorrow) to put the other 3 on the unit next to it. I fully expect 4-5 days each unit dehydrating, that puts me at finding my YJ if I need to do any more dehydrating this week !!!
  11. #37
    Atlanta GA area
    And I thought I was crazy having 3 DigiCools on my van (well 2 now, I sold one of them).
    GA-HVAC-Tech
  12. #38
    May 2011
    New York
    Working on larger chillers changes the rules. When I do smaller units (under 20 tons) the tool list is vastly different from whats being used with the Mammoth ones now.
