Results 1 to 2 of 2
    Jan 2003
    Kansas City
    modutrol IV motor
    This mod motor is mounted 2 inches form top of unit, so I can't see anything....The motor is driven by a johnson controls discharge temp thermostat with a 2-10 vdc output to drive a gas valve to maintain discharge temp. My quetion is...is the interface control mounted in the mod motor adjustable? The motor only drives 35-40 degrees with max and min voltages applied. The motor is supposed to drive 90 degrees.
    Aug 2000
    Under my tree
    I believe it is adjustable. I usualy hook my signal generater to the actuater to calibrate it. That way I know it will drive properly when I put the control wires back on it.
