+ Reply to Thread
Results 1 to 20 of 20
Thread: Smardt Chiller Repair - Turbocor
    Oct 2005
    This was my first repair on a turbocor compressor. The IGV on compressor #1 stop responding.......couple months later compressor #2 IGV stop responding and got stuck in a fixed position just like #1 compressor. We talked to DTC they said there was a problem with some of the IGVs installed on some of the ealier compressors. Just finished up the repair today...... compressors came online and loaded up correctly.
    Name:  photo 2 (2).jpg
Size:  39.9 KBName:  photo 1 (3).jpg
Size:  41.7 KBName:  photo 2 (3).jpg
Size:  43.9 KBName:  photo 3 (2).jpg
Size:  39.6 KBName:  photo 4 (2).jpg
    RTFM!!!
    Dec 2011
    Australia
    Looks good. What was the problem with the IGV? What year was the compressor built?
    Oct 2005
    The IGV was stuck at 20% it would not open or close.
    I just realized I posted in the wall of shame Can someone move it to the commercial forum.
    RTFM!!!
    Anytown USA
    Thanks for sharing the pictures
    Jan 2011
    Quote Originally Posted by manny238 View Post
    I was wondering why this was in the HOS! Ping one of the moderators, they can move it for you.
    Dec 2011
    Australia
    Did the ball bearing in the peep window indicate that it was stuck at 20% Or did it move the full 0-100 range? Did the IGV test ok?
    Moved to Tech to Tech Chat Commercial
    Oct 2005
    Nope the ball bearing would not move...... also ran numerous test on the IGV it would not respond at all.
    RTFM!!!
    Oct 2014
    hi, i have a problem with a turbocor, the control board dont have power, i need a service manual or some kind of help.
    May 2015
    Hi, we installed two TT-300 and have some problems.
    Jul 2011
    Aurora
    what happen to the operation before repaired? did it not maintaining set point or else?
    we have thermal care chiller that using 2 turbocore compressor. so far is operate smoothly.
    Oct 2005
    Quote Originally Posted by cfe View Post
    Could not maintain set point.
    RTFM!!!
    Jun 2015
    if IGV works correctly, it will open 110% in maximum position
  14. #14
    Jul 2011
    Aurora
    how do you test the IGV operation? is it thru the I/0 connector and danfoss sofware on your computer ?
    i have a turbocor compressor # 2 that IGV only go up to 12 % . the ball bearing not even move stay closed.
    after numerous time its tripped. no refrigeration effect at all.
    did not see any option on chiller control panel. this is Arctic cool chiller.
  15. #15
    Jun 2008
    Windsor, Ont.
    You test the IGV operation with Turbocor 3G software and a connection through the interface board..
  16. #16
    Apr 2009
    San Diego, CA
    I had the same thing happen in January. Compressor #2 started then shut down after about 15 min. Bad drive motor.
  17. #17
    Phoenix Arizona
    the manufacturer of the chiller should be able to provide the Turbocor service manual...You might be able to find the new one online, I couldn't but didn't look very hard...There is a section in the back on how to test and verify almost everything in the compressor...You have to put it in manual mode and set the IGV steps. I believe around 12000 is full open 6000 is around 50 and should be the starting percentage...
    Your starting % and max steps could be off and causing problems...I check a known good compressor's values when I run into these problems...
    "If history repeats itself I am so getting a dinosaur"
  18. #18
    Jun 2015
    Toronto
    You can put the compressor in manual control mode and open the IGV to 110% all through the SMT software
  19. #19
    Oct 2005
    Smardt had a problem on there first generation chillers where the set screw was coming loose. I know they sent me something about it, id have to check when I get home. The new IGV comes with a new redesigned suction cover. Still fits in the same as the old one.
    You can try to contact Smardt but I'm not sure how helpful they will be.
    RTFM!!!
  20. #20
    Dec 2012
    Lowell,MA
    turbocor.com
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
