Results 1 to 7 of 7
    Aug 2009
    Plano, Texas
    Overload relay fire continued
    Sorry for starting a new thread. I could not figure out how to post pictures on a reply to my last thread. Here is this job finished up. The first picture is of my work station for a couple days. The second is after I finished all the control wiring. The third and others are after it had been cleaned up and all consolidated into one line. This is my first completed post on the WOP, and I'm really proud of this one. Started right up with only a couple error codes. Had those resolved in under 30 minutes and It's back online with only a few other things that will need to be quoted. All bypass valves and fan cycle controls still worked thankfully! haha. Thanks for all the good words guys.Name:  photo1.jpg
Size:  89.3 KBName:  photo2.jpg
Size:  163.3 KBName:  Photo3.jpg
Size:  113.7 KBName:  photo4.jpg
Size:  105.8 KBName:  photo5.jpg
    Also, Lennox no longer made many of the lower voltage wiring harness for all the boards. I had to order multiples of larger harnesses cut and rearrange wire ends in them to retrofit. Worked like a charm! So, if you're ever in this situation and have to replace some of those white terminal strips and you cannot get them get the p118 that's 16 connections long and make to fit.
    Looks really good.
    Sent from my SGH-T999 using Tapatalk 2
    Jan 2011
    Metro Atlanta
    Nice and clean. Nice job! How log did that take you to clean up?
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    Nov 2009
    Central Virginia
    Nice job! You should be proud of that. You should get a raise for that lol!
    Sent from my SPH-D710 using Tapatalk 2
    ____________________________________________
    If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
    Aug 2009
    Plano, Texas
    Quote Originally Posted by NY2GA01 View Post
    Just to clean up the wire, a little less than an hour. The whole job took about a week. That includes the whole re wire and installing controls. New 10 hp motor, shaft, wheels, bearings, and alignment. Two new exhaust fan motors and rewire on the back side.
    Jun 2009
    Alberta, Canada
    wouldn't it be quicker and/or cheaper to replace the whole unit?
    Have tools and gauges, will travel.
    RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
    Jun 2009
    South Carolina
    Excellent work. Nice and Tidy.
