Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 77
  1. #27
    Quote Originally Posted by lytning View Post
    Another great review. I still have leak lock and use it. I have the Nylog but haven't used it yet. After reading this I think I will.
    I despise that crap. If you feel it's necessary to repair a leak, it's time to look a little closer at the mating and sealing surfaces and determine WHY they are leaking.
  2. #28
    Aug 2009
    Maine
    What crap, the Nylog or the Leak Lock. Both have uses. The Nylog for hoses and maybe gaskets. The Leak Lock for threaded fittings. I think some manufactures are recommending Nylogs use.
  3. #29
    Leak Lock.
    I have worked for all these years in the trade and haven't needed it. I doubt that I'll find a need for it tomorrow...
    A little teflon tape will do MUCH better because you can take the joint apart at some later date if required.
  4. #30
    Jul 2005
    Phoenix, AZ
    Do you apply it to the threads of the fitting or the back of the flare? Just curious. I have been using it on the threads.
    Sent from my DROID RAZR using Tapatalk 2
  5. #31
    threads
  6. #32
    Jul 2005
    Phoenix, AZ
    Cool thx!
  7. #33
    Feb 2012
    Maine
    Ill have to get some and try it. Thanks for the review.
  8. #34
    Leak Lock.
    Same here on the Leak Lock.
    When I find it on service valve or service port caps, I want to find who did it, and bludgeon them to near death, let them heal, then bludgeon them again...
  9. Likes kamersoutdoor liked this post
  10. #35
    x2
    Sent from my SGH-T999 using Tapatalk 2
  11. Likes kamersoutdoor liked this post
  12. #36
    Feb 2005
    I use nylog as well,even on flares for lubrication,i don't like leak lock either because it hardens and it is hard to loosen to remove,i like Loctite 515 for thread joints,it doesn't harden so joint can be taken apart easily
  13. #37
    California
    Quote Originally Posted by phxhvac View Post
    I put it on the threads, the face of the flare, & the back of the flare.
    anywhere metal touches metal and will have a twisting friction...I want lubricated.
    Nylog is basically gelatinized refrigerant oil, It doesn't dry up and harden.
    Any excess that comes out of the joint, wipes up outside of the joint, and inside of the joint, will wash away as refrigerant passes.
  14. #38
    Jan 2013
    Leak Lock...been a staple of the industry for years an I think it will stay that way.
    If I have to install a TXV on a new install, then I will use Leak Lock.
  15. #39
    Quote Originally Posted by hvac5646 View Post
    There isn't any part of any mechanically fitted TXV used in the industry today that should have Leak Lock put on it, or that would be helped by the addition of Leak Lock...
  16. Likes kamersoutdoor liked this post
