    Jul 2009
    Columbia, MD
    Zonex Systems "System 2000 Gen II"
    Anyone know about these zones or have good manuals on it?
    I have a 7.5ton system with this controller. It has 2 slave stats and 1 master stat.
    There are 2 supply dampers and 1 bypass. The 2 slaves connect to their own damper.
    The master stat has no damper connected to it.
    If you turn the 2 slaves to off, and turn the master stat to heat on, the system will run the heat. The master has no damper to it. So the heat will run with the 2 dampers closed.
    Is there any way to have the slaves control heat and cool?
    Mar 2010
    Tidewater Virginia
    Gravity, Try www.zonexsystems.com/lit.htm and download the Gen II manuals. Factory tech support is 800-228-2966 and don't forget their on the Left Coast, so wait until about Noon or after.
    Jul 2009
    Columbia, MD
