Results 1 to 13 of 14
    Jan 2006
    Refrigerant leak on sight glass,semi herm.
    I may have caused it,i dunno know,but i know its a leaken,customer called freezer a little warm5 degree,found refrig. leak around sight glass,i thought easy fix,ya,i took a straight screw driver and a hammer and tightened it up a bit and checked again,its still leaken,with a closer look the sight glass has got a hair line crack in it,i prob caused it when trying to snugg up leak,screw driver slipped and hit the glass,anyway its got a hair line crack and i tried to rig it with a round piece of steel and a gasket but with no luck,still a leaker.Any suggestions other than changing the compressor?Thanks.Man ive had one of those weeks.
    There are three signs of old age.
    The first is your loss of memory,
    the other two I forget.
    N.E. KS
    I Take It You Dont Have A Bone Yard To Resort To. What Compessor #, Maybe Someone Else Has A Junker Sitting Around. Just A Thought.
    Some people know the cost of everything but the value of nothing.
    Jan 2006
    Ya ive got an old one thats bad sitten around but didnt know if it would seal the leak or not,its a gasket type thing,you know how a old gasket is.
    Hillbilly, sight glass kits are available through your local wholesaler, if desired. I'd go that route. Why change the compressor?
    Oct 2002
    North central Massachusetts
    I would think you could get a sight glass and gasket for them. I'm sure for copeland or tecumseh. I think you are right basser.
    Jul 2000
    Treasure Coast/Florida
    Copeland P/N 998-0002-04 Sightglass Kit (K,E,L-Bodies)
    Monmouth Junction-NJ-USA
    And you might have to make your own wrench from an old socket. Use a 4" grinder to fabricate the tool.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Jan 2006
    Thanks fellows,i ordered one today from SWH,and called Copeland which is really Emersom but didnt know this,they said the glass part would blow out with a little pressure behind it.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by hillbilly tech View Post
    ya and i have changed them before,
    go to home depot and purchase
    a peice of 1 inch flat steel, cut a peice
    about 6 inces long, stick it in the
    slots and unscrew with crescent wrench.
    Alberta, Canada
    your lucky you did not eat that sight glass when you smacked the ring with your screw driver.
    "I'm really easy to get along with once you people learn to see it my way."
    "I'll try being nicer if you'll try being smarter."
    Dec 2006
    In a Mess
    this is my little tool, make one your self with some hard steel annd a dremmell too, works great!
    mike
    Sig removed by mod. G-Rated site
    Dec 2006
    In a Mess
    oh, steel is 1/8" thick!
    Feb 2007
    Northern NJ
    sight glass kits available from wholesaler, also, use a drag link socket to tighten sight glass, this socket has a wide screwdriver type blade at end to reach across entire sight glass.
