Results 1 to 13 of 26
    Mar 2013
    New Orleans
    Mini Split Help!!!!!
    Hey guys Ive been coming to this forum to read up when Ive had questions for years. Today I had to sign up because I have a customer who has me pulling my hair out. First problem is that he is a Mechanical engineer, second he called me but doesn't know why he called me, and third he has a wad of cash to blow. He wants his 1200sqft house outfitted with minisplits in 3 beds the kitchen and living room. No problem right???? Wrong he doesn't want a multi zone set up using one condenser, he wants an individual inverter condenser for each room. yes that's five condensers!!!!!!!!!!!! he is swearing that it will be way more efficient this way. I'm telling him he has lost his mind all together. I'm trying to explain that running five appliances will always be more than running more. At this point he whips out a four page calculation he did. I'm not joking. And then tells me he was given my number because I'm the guy who will get done and get it done right. (oh flattery) I told him I would do it but would not grantee that he will get the results he wants. Then i told him i need a day to do some research before we sign any paper work. What's your take on this???? By the way walls have 4" foam open cell, attic has 12" closed cell, windows are all insulated and have sun shades. Also has a 6 inch fresh air duct with dehumidification and double filtration that he designed and installed him self. All electric appliances. In New Orleans.
    Dec 2011
    somewhere between here and there
    lol
    pretty sure no matter what u do it will not be good enuf for him....say goodbye and wash your hands of him....
    if not...repost in six months and let me know!!!!!
    Please, Please Please......keep the Factory Smoke in the Wires!!!!!
    Is it Rum'Oclock yet???
    Well, he has a point. The single zone units are available in significantly higher efficiency than the multizone units.
    Really put a dent in his pile of cash and sell him 5 Daikin Quaternity units.
    Mar 2013
    New Orleans
    Well i told him today that Friday I would present him with a couple different proposals for different options and that if he wanted me to do the work he would have to choose one of those. I'm trying to sell him on fujitsu, daikin, or mitsubishi. I can easily get these brands in my area. Thats when he made the comment that it would not only be more efficient with independant units but also if the A/C went down in one part of the house the rest would not be effected. He has a point there and I can understand that. But now my question is still, will it be more effecient with independant systems? Thats my main concern, I pride my self on being able to cool and heat a home in the most effeicent ways available to me amd my customers. And i'm not sure if my thinkingt is correct on this, but it seems to me that the more units you have the more power they will consume. For instance if you have five units running off 115v with a 16 seer energy rating they will use more power than a single quad zone 16 seer 230v unit and one single zone 16 seer 115V unit. Is there something wrong with my thinking it costs more run more units??? Personally I'm running two fujitsu tri zone 18 seer set ups at home. one for the bed rooms, the other for the common areas.
    Jul 2001
    Gold Coast of Connecticut
    I believe with the smaller compressors cycling and higher seer single units will run much cheaper (10-20% less)
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Mar 2013
    Joplin,Missouri
    If you dont walk away from it you will spend every saturday night for six months at his house working on nonexistent problems everytime a cricket chirps or he hears a noise he will be blowing your phone up thinking something is wrong or it is a half degree off of his estimated temperature drop or some bs he will be calling you
    Mar 2011
    phillipsburg, nj
    walk away or he will own you and drive you insane
    Dec 2009
    Bristol NH
    Quote Originally Posted by njtinman View Post
    I would definitely second that! Every customer I have ever had that said I was there because they only trusted me or blew all kinds of sunshine up my skirt about how awesome I was, ALWAYS turned out to be THAT customer. If you take it give him a 10 page detailed proposal and make enough on it to be happy that you just got a new " friend".
    Sent from my XT907 using Tapatalk 2
    Athens, Ohio
    Take the job. Install Mitsubishi High Heat units. The higher heat output is not available in the multi-zone units. Do as has already been suggested and make sure you specify in your contract precisely what you will do, as well as just what your warranty obligation and limitations are. He's going to spend more money for 1:1 units but that's what I'd want if I felt heating costs were a priority.
    I would mention to him the limited tax credit for air to air units and the far larger tax credits for geothermal.
    Quote Originally Posted by kdean1 View Post
    I'm thinking that in Lousyanna, the humidity setpoint control on Daikin Quaternity systems would be more of an advantage than Mitsubishi's higher heating capacity.
    Athens, Ohio
    I'm not familiar with the Daikin or humidity setpoint control. Does it differ from the Mitsubishi "dry" setting?
    Also, is the customer by any chance also a pilot? They love redundant systems. As long as he knows several individual systems will cost more than a couple multi-zones I don't see it as a problem.
    butler pa
    or let him spec it out and you install..since hes a genious
    burlington county n.j.
    Quote Originally Posted by pauls heating & View Post
    someone who knows what he wants and has the cash to buy it.
    he's a friggin dream customer.
