Results 1 to 2 of 2
Thread: Honeywell TZ 3
    Honeywell TZ 3
    why do I have 1.5 V on a single zone and 0 volts on the other 2 during idle periods? The system is set up as power close, spring open so I believe that I should have 0 volts on all 3 zones during idle periods. this is a 24vac system - will the 1.5 v on the actuator create a problem?
    Grottoes VA
    Ghost voltage
