    Mar 2013
    Chilled water closed loop
    I am having a foaming discharge from my auto air purgers. Is this an indication of air infiltration?
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by crackerman View Post
    Either that or you popped a tube.
    ...Ron
    Roof Rat
    Mar 2013
    We recently did a eddy currrant test on condensor side it did not indicate any negative results.
    Aug 2009
    Prattville, Alabama
    Not to say you do or do not have a tube leak, but a leak at or near the end of the tube probably won't show on an eddy current test. And a leak between the tube and the endsheet won't either. That foaming discharge from the air purgers could be caused by a number of things. Since we don't know what refrigerant your chiller has, or the application (comfort? process?), or if the system has been disturbed (opened for repairs?), or what your operating pressures are (possible pump shaft seal leak), it is difficult to think of all the possibilities.
    Jan 2005
    Houston TX
    Did you try and put a leak detector in the not so close proximity of the foaming air bleeder. What are your system pressures (water side) is any part of it below atmospheric pressure ?
    Having sex is like playing cards, if you don't have a good partner, you better have a good hand. !!!!!!
Tags for this Thread
