Results 1 to 7 of 7
    Kuala Lumpur, Malaysia
    location of liquid drier
    as for 1 hp ductless air-con outdoor unit, after a compressor replacement after burnout, where shall I put the liquid line drier, somewhere in between condenser and capillary tube or after capillary tube ?
    N.E. KS
    Liquid line filters go before the metering device.
    Some people know the cost of everything but the value of nothing.
    Some ductless systems are not supposed to have a filter drier.. You should check with the manufacturer about it for your specific unit. We have already installed filter driers for 1 day after a compressor change out and then removed them.
    actually which one is more suitable for the cleaning work after compressor burnout? liquid line or suction line drier ? or even both ?
    Quote Originally Posted by dknytech View Post
    we do both liquid and suction along with a R-11 flush....
    then remove both filters after a day.
    Houston,Tx.
    And a good long vacuum probably would probably not hurt much either.
    Quote Originally Posted by mrbillpro View Post
    yes i totally agree.. anything over 400microns is unacceptable.
