Thread: penn 266
    Jan 2012
    Question penn 266
    Hi, can we resume the factory default setting on this control and how ?
    Salt Lake City/Tooele
    Like asking what is the spark gap for my V8 engine. There are numerous V8 engines out there and each is a bit different. As with the Penn 266 series condenser fan controls, there are numerous models, which is yours and how it corresponds to the existing equipment is in the air at this moment.
    Here is a publicly accessible brochure and install manual on that series of controller, outlining what the numerous models are and what they can and can't do with the transducers installed.
    http://cgproducts.johnsoncontrols.co...F/12011534.pdf
    http://cgproducts.johnsoncontrols.co...2476642705.pdf
    Jan 2012
    The question is , can we resume the default setting, when another programation have been done. no matter which 266, thanks .
    P266 Series Control Setup Values and Modes
    The P266 Series Control ships with up to ten factory
    default setup values and modes. These settings can be
    adjusted in the field (if required) to meet your specific
    condenser application requirements.
    Sep 2006
    Ohio
    Yes, you can change the settings back to the default settings.
    SE Pennsylvania
    Manual
    Page 11 is the default settings. You will need to set each one manually back to default.
