    Feb 2007
    Central NJ
    Fieldpiece S365 & s365XL
    Anyone using one? What's your experience? Will it work On rheem/ruud units?
    Is the S365XL out yet? What size units does it cover?
    You have to pay your due's before you pay the rent!
    Quote Originally Posted by n-e-w Jerz! View Post
    Anyone using one? is a good tool
    What's your experience? works good far more accurate than fan cycling to attempt to find out where the system is, and easier to use than the old raincoat i was using to block the coils with, and it hasn't let me down.
    Will it work On rheem/ruud units? yes.... yes it will.
    i don't know what size units they cover, as i always just cover then fan orifice and the standard size always has got the job done for me.
    hope this helps
    Feb 2007
    Central NJ
    Thanks Beach, defiantly going to invest in one I think! Sick of wraping coils and expecting "accurate" results.
    Oct 2008
    Fullerton
    We set aside the XL version as it just didn't have the right effect on package units because the fans are on one side of the unit. The S365 does work great on split systems and I haven't seen one that it doesn't fit small or large.
    it can be done with wrapping, but it most certainly isn't as easy IMO
