Results 1 to 13 of 17
    Mar 2013
    Condensing Coil Cleaners
    I wanted to know from the community which coil cleaner is the best! There are so many to choose from and I need some. Wanted to save time and money in testing the different ones. Wanted to know the product and what your paying. Thanks in advance!
    Mar 2013
    I heard the one from Ace is good, is it?
    Feb 2007
    milford ct
    i use nu brite for condenser coils. but you need to rinse it off well . and cal clean hd for the evap coil's
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
    Jul 2012
    Western KY
    Quote Originally Posted by bacciagalupe View Post
    X2
    Feb 2013
    New Orleans, LA
    X2
    x3
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by nolaHVAC View Post
    x3
    x 4 for the nu brite. My old company only used that stuff and it worked great.
    My current company uses the Ace Foam and clean, so that is what I use for their work.
    In my opinion the foam and clean does NOT work half as good, but untill they tell me otherwise, or I change companies that uses the Nu Brite, that is what I will use.
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    What about pressure washing? Anyone go this route?
    Sent from my SGH-T999 using Tapatalk 2
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by hvac wiz 79 View Post
    NO.
    It's Kinda hard to do that without messing up the coils big time.
    When I first started doing this someone told me coil cleaners are a joke and nothing but a waste of water and expensive cleaner, and all you need to do a better job was an air compressor to blow it out, and that would get it spotless.
    I only seen that done one time. One day at school a student brought in a condenser that need a new compressor. The school allowed him to bring it in so the class could learn how to change out the compressor, it needed to be cleaned and no one had any cleaner, so they go the air hose and blew it out. I have to admit, it worked, but if you held the air too close it damaged the fins.
    Coil cleaner, and low pressure water is the way to go in my opinion
    Jul 2012
    Western KY
    Nope. Waste of time IMHO. I have found a good foam and water volume produce the best results.
    French Settlement, Louisiana, United States
    Sold a couple unit to HO's that pressure washed their units
    And Nu brite is the wAy to go!
    Apr 2012
    Cleveland
    I'll go with nu brite as well. Most of nu calgons line is good depending on what you need it for. The company I work for uses some cheap foaming stuff that barely foams. I honestly haven't paid attention to the brand, but it sucks. No no no on pressure washers.
    Jul 2012
    Western KY
    Also. I will not use cleaner unless needed. If its a unit I maintain it gets washed out twice a season and does not usually need chemical. But if its a unit that only gets attention when it quits cooling then ill put the nu brite to it.
    Quote Originally Posted by coolcajun View Post
    There's a method to correctly doing it. If techs, helpers and coil cleaners thoroughly rinse the coil and surrounding ground area all is ok. My only gripe is when guys fail to do it right. Coil cleaner has its place but not in everyday cleanings
