Results 1 to 9 of 9
    Mar 2013
    Can you believe this didn't leak at all?
    Name:  2013-03-15 09.20.48.jpg
Size:  41.7 KBName:  2013-03-15 09.20.42.jpg
    Just had this removed and replaced with a 2 ton Heil split system.....
    It was still functioning, although not as efficient or effective
    18 year old Rheem system......
    Not uncommon for the press sheet to look like that, and the copper be in good shape and not leaking.
    Those Multiflex coils were tanks. Almost NEVER leaked, except in horizontal position it seemed.
    Jacksonville, FL.
    On the other hand, they're a pain to clean unless you remove them entirely.
    WHY?
    Oct 2011
    between here and over there
    seems like the older equipment is good to go! some of theses units that are 10-15 years old and dont have a leak nor a bunch of problems, and the customer doesnt do much or no PM on the equipment. I have seen worse coils than that with no leaks, then we jump 15 years and I see new coils that dump 10 lbs of refer with in a year from start up.
    Mar 2013
    Central IL
    Seems to me if it's old and still running leave it be. The new or replacement stuff we get today just does not last very long at all. Replaced some blower motors on room units 3 years ago and had to go back and replace them already. Sucks a company like emerson got bought out by A.O. Smith. (cheap)
    Mar 2013
    Quote Originally Posted by Abrnth3 View Post
    The old unit was simply not able to keep up with the summer heat anymore, the blower was not working well, and there were some electrical issues coming up with the condenser, it was definitely time to retire the old unit. The new unit, has been installed much better than the old one was, and is providing a much higher level of comfort. Here's hoping I can manage at least 18 years from the new one, with less service calls for repair needed along the way.
    Arrow
    A.O. Smith bought Emerson I don't think so!
    Mar 2009
    Mount Holly, NC
    Quote Originally Posted by wmunn View Post
    perfect reason for a service plan with cleaning and preventive maintenance.
    only reason it would not be able to handle the load is if it was undersized, or if if was dirty.
    properly sized equipment will not handle a load if the ductwork is leaky also...
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
