Results 1 to 13 of 22
    Jan 2011
    Going to start on this one soon.
    First solo geo job. Should be fun! Should get started next week. Loop guy should be there by then, if the weather cooperates.
    Coming out is 1972 vintage bryant 80%ers. Nice duct systems, not changing much of that.
    Going in is 2 Bryant Evolution 98% furnaces/controls and coils, 2 of Waterfurnace's 26 eer units. Pairing the desuperheaters, one loop, one flow center hardest part is going to be getting my lineset upstairs..
    Ill update this with pictures as things progress.
    Jul 2009
    Columbia, MD
    make sure you use the proper lines. if you go over 60' i think. you need to upsize to a 1/2" liquid line.
    good luck. it will be a fun job
    Jan 2011
    Quote Originally Posted by gravity View Post
    Should be good on that, Shouldn't be no more than 25 feet to the upstairs. Basement one is right next to the geo's.
    Yes I will have ball valves after the flowcenter. Loop guy does all that, or at least he said he likes to. Supposedly does pretty tidy work. I hope so!
    Jul 2009
    Columbia, MD
    add some ball valves in the geo supply and returns to set the flow. i used a WF solenoid on my lines so i didn't have water flow in the unit thats off.
    Jan 2011
    Here is the downstairs unit that comes out. Unhooked the ac today and measured it up for the transitions and return drop. 1986 Bryant, never had gas added. Not a bad install at all minus the wild drip leg ha! EAC was long ago switched over to media filters, as most are.
    Think I am going to reuse the lineset for the upstairs, or well what is in the wall going up there. Need to get at least a 4 wire stat wire up there though to run the geo.
    Jan 2011
    Got the desuperheaters plumbed. No leaks.
    Jun 2007
    Quote Originally Posted by jimmyed View Post
    I was under the impression that you cannot use a gas hot water heater with a desuperheater? Maybe I am ms-led?
    Jan 2013
    Frederick, MD
    Quote Originally Posted by Kevin Weaver View Post
    Work looks amazing (with the exception of the source piping) but Kevin is correct. You are not supposed to hook a hot water generator to a gas water heater.
    Nov 2009
    MO
    Is that soft copper? Looks good. Boss has our guys use pex for desuperheater. Looks like crap. I'm anxious to see your linesets. I've never been happy with mine on those split systems.
    Sent from my USCCADR6230US using Tapatalk 2
    Jan 2011
    Yeah, just 5/8 lineset left overs.... Bending it saves using fittings.. Only used 4 street 90's and 3 tees. Plus my shutoff's and check valves.
    Jul 2009
    Columbia, MD
    looks real good!
    Jan 2011
    Couple of twins I picked up today, damn 5 ton coils are big! Got all my sheet metal made, gonna change the downstairs unit tomorrow. Upstairs maybe thursday.
    Jan 2011
    Took me a day and a half by myself to get the basement furnace changed and lineset ran, nim control, and flues ran outside. Working on the upstairs unit tomorrow. Loop guy supposed to be there tomorrow as well.
