Results 14 to 20 of 20
    May 2002
    6PSIG DROP = 160GPM
    Strainer clean.....
    To the top...
    mikeacman
    East of big city prices.
    You know I keep looking at this situation you have here and the only weird thing I see is your approach. That would be good for a flooded evaporator but we have a DX evaporator.
    Could your BPHE be fouled with excess oil?
    I don't deal with PG too much but you have the flow could the mixture be too high like chilbrig eluded to?
    Quote Originally Posted by mikeacman View Post
    6PSIG DROP = 160GPM
    Strainer clean.....
    To the top...
    May 2002
    I don't believe so....
    I currently have propy glycol at 35%
    My earliest of posts stated dowtherm and it read high ,as in 40+%, but i was assured by the plant engineer that all they use is dowdrost.
    Monday ,when another tech was there ,we discussed everything that had been checked and the valves never got below 40% with the pretty much same conditions and load ....
    i was 20 degrees warmer outside ...
    May 2002
    What would YOU expect the approach to be ? Not a trick question , just curious..
    I assume your saying you would expect the approach to be 2-4 not 7-9 ?
    May 2002
    update... Chiller is fixed....main base board issue .... Replaces main base board everything is ok....carrier engineer admitted to some flaky boards being out there
    mikeacman
    Jul 2012
    Western KY
    Nice. Hadn't heard that yet. Good deal.
    Sounds like a good explanation to me I guess.
