Results 1 to 13 of 20
Thread: airhandler supply hole
03-20-2013, 08:13 PM #1
- Mar 2013
- 18
I just had an ac installed and they covered part of the supply on top of the handler to make main duct more narrow,,is this ok,,,thanks
03-20-2013, 08:18 PM #2
Post some pics please.
Sent from my SPH-D710 using Tapatalk 2____________________________________________
If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
03-20-2013, 08:48 PM #3
- Mar 2013
- 18
03-20-2013, 08:50 PM #4
Professional Member*
- May 2007
- DC Metro area
- 3,225
No transition...not good for airflow (or the equipment).
03-20-2013, 08:51 PM #5
No. That's not okay. The airflow is now severely restricted. You need a transition from the new unit to the existing ductwork.
I'm now curious as to how the whole install looks.
03-20-2013, 08:58 PM #6
- Mar 2013
- 18
thanks for the answers,,its a goodman avptc426014,, I did not think that was right,,and I think system is too big 3.5 tons I got 1400sqf under ac,,,(miami fl)
03-20-2013, 09:00 PM #7
- May 2007
- DC Metro area
- 3,225
Considering how the inside looks, I wonder if they adjusted the variable speed air handler from the factory setting of 5 tons (~1800 cfm on that particular model) to 3.5 tons (~1400 cfm max). How is the noise and force of air from the vents?
I would have this corrected. 3.5 tons for 1400 sqft? Very likely oversized. Perhaps double what your home's actual load dictates. Not good for efficiency, comfort, or longevity (especially the way yours was installed). At the very least, beyond (properly) installing properly sized equipment, I would want the transition corrected and air handler speed set properly.
03-20-2013, 09:06 PM #8
Could we see a pic a little farther out showing complete duct
03-20-2013, 09:07 PM #9
- Mar 2013
- 18
thanks,,,and i think its too big 3.5 ton I got 1400 sgf,, ac runs for only 3-9 minutes,,
03-20-2013, 09:12 PM #10
you should not be touching this unit. Call the installers, send a registered letter but do not touch it.
Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
03-20-2013, 09:12 PM #11
Sounds wayyy to big.
03-20-2013, 09:19 PM #12
- Mar 2013
- 18
03-20-2013, 09:23 PM #13
That install is junk. I hate when people get this kind of service.
Sent from my iPad using Tapatalk HDTo the man who always did it right. I love you dad and I will miss you to much for words.
Stay Thirsty My Friends
Support the Skilled Trades Don't DIY
