Results 14 to 14 of 14
    SW FL
    GREEN HEAT the SpeedWay
    In those rates, I don't know if you factored in that with electric resistance or hydronic bakc-up the HP keep running and generates heat, so the ocmposite COP is >1, WIth a dual fuel, it's either/or, so you don't get to run the heat pump while the furnace is running.
    For example, with a Carrier Greenspeed heat pump, it's optimized for capaicity and according to data sheets actually has a lower COP <40F than a Infinity 16 or 19 heat pump. However, it produces a lot of capacity, so it won't need the heat strips nearly as much, so the overall effciency is much much higher.
    The power level is increased to provide a somewhat level heat output.
    Greenspeed 4 ton added to graph.
    It sure limits any significant need for Aux Heat.!
    Designer Dan
