Results 1 to 8 of 8
    Sudbury, Ontario, Canada
    Combi dhw heater or combi space heating boiler ?
    What are the factors that must be considered when trying to decide on which technology to use ?
    Jul 2000
    Northern Wisconsin
    The main difference is how they were designed and rated. They both do both.
    The deciding factor should be how you plan on using the unit and what features are most important. Then the final thing to consider is which unit fits your needs without compromises. <See my tag line below>
    May 2008
    Missouri
    What do you want to do with the unit? We've installed combo units that will do both, but is that what you want?
    Well I have a 1 1/2 storey heated with a medium efficiency 125,000 BTUH input gas boiler, and a separate medium efficiency gas water heater. The house is heated with cast iron radiators fed with large gravity feed pipes. Only two people living in house with one bathtub. Would like to migrate to a single source high efficiency mod/con heating plant.
    Originally thinking mod/con boiler with instant DHW was way to go, but then started reading about possibility of a potable mod/con water heater for space heating. Seems that the potable water heater would be slightly more expensive to operate due to larger volume of water being maintained hot in the hot water heater. What other issues are there to consider ?
    That 125K is likely oversized, water heating needs don't add that much. So 660K used boiler can heat about 5 houses on your street!
    There are mod-cons that will do both, house heating and domestic though domestic capacity can be pretty minimal. Some of the hot water gurus will be by eventually with some suggestions.
    May 2012
    Upper Michigan
    Triangle tube makes a excellence series boiler that would do both for you. Look that up.
    May 2012
    Upper Michigan
    I think you have addressed a couple threads with that reply lol.
    Jun 2010
    Philadelphia PA
    Of course the combi units will modulate (turn down) so the oversize problem is minimized AND the con boiler just loves those big rads with no chance of the problem of low return temps SO twith outdoor reset you may have a really sound approach under consideration
