Results 1 to 13 of 25
Thread: uv leak dye
    Mar 2013
    swan valley idaho
    uv leak dye
    hey guys, just read a alod thread were alot of people are bashing the use of dye. Dye has worked great for me several times, very easy to visually check system and find leaks most of the time. Chevy puts in every car they make since 2001. i have never seen it hurt a system.
    Can anyone really honestly say they dyed a system, and shortly after it hurt it? curious . maybe i should stop using it? it does work really good to find leaks.
    California
    why even use the dye?
    Just put in super seal.
    Oct 2011
    Chicagoland Area
    Well, If Chevy does it....
    It's messy and stays in your hoses forever
    Jul 2005
    Phoenix, AZ
    It also voids the warranty on equipment if it is used. It displaces what the filter drier catches and blows it out the back of the drier. Plus it makes a mess of your gauges.
    Sent from my DROID RAZR using Tapatalk 2
    Dec 2006
    In a Mess
    who got that UV light pic of the rack with a gallon of Dye added? hahah
    Sig removed by mod. G-Rated site
    Aug 2012
    willowick ,oh
    messy and un-necessary. If you cant find a leak without it, u r in the wrong trade.
    Sep 2010
    Quote Originally Posted by heresjohnnyb View Post
    Isn't that the truth.
    It is a great tool to have available for situational use, but I wouldn't use it in every system.
    Quote Originally Posted by phxhvac View Post
    Maybe your experience is with crappy products, Spectroline Ar-Glo doesn't do either of those things.
    Only if the system has been over treated.
    How would you propose to exactly pinpoint every leak in a system that is in an environment where you are not allowed to use an electronic leak detector, like a walk in for volatile HAZMAT storage?
    I used to use it. Works great. Never had a problem with it.
    Haven't had the need to use it lately.
    Mar 2013
    swan valley idaho
    Never have iether. like i say GM it uses it in every vehicle made since 2001 from the factory.( was a GM factory tech for 8 years) all with 134a. It is easier by far to find leaks than electronic IMO. yes-do it right, and don't over dye. it only takes an ounce or two usually.
    Anyhow noone ever answered that they have actually seen it cause damage to an otherwise good system? so, has anyone?
    Also then, what are your favorite detectors/brands/methods for leak checking. If someone has proof i would like to stop using it, but it does work great for finding leaks.
    Jul 2012
    Western KY
    Used it once when I was a baby tech. NEVER agin. 23 years later still haven't had a leak I couldn't find with out it. Don't care if its good, bad, or indifferent to operation. May help you on the first leak but then its everywhere. Here a leak there a leak everywhere a leak leak?
    Mar 2013
    swan valley idaho
    so what is your preffernce then make model etc...
    Preferences:
    Electronic: H-10. Have a H-10 PM and a H-10 G. Very satisified with the PM, only used the G a handfull of times.
    Soap Bubbles: Current favorite is a homade mix of awsome cleaner/degreaser and water. Also have super blue and some thick yellow stuff (not sure of brand). Nu calgon brand works good too.
    Also have a length of 3/8 od hose, stick one end in my ear, run the other end around the evap elbows or whatever I'm checking.
    I think the last time I used dye, it was the spectronics brand.
