Results 14 to 26 of 31
Thread: Testo 552 Micron Gauge
03-16-2013, 05:12 PM #14
Have you ever used the BluVac at colder than it says?
Be willing to bet thats as cold as he could test to in his Florida Lab LOL“If You Can Dodge A Wrench You Can Dodge A Ball”
03-16-2013, 05:24 PM #15
03-16-2013, 05:41 PM #16
03-16-2013, 07:32 PM #17
03-16-2013, 10:14 PM #18
03-16-2013, 10:26 PM #19
That must be a newer one chuck. At some temp (<32 maybe) the programing slows the display so it can be keep up in the cold.
04-01-2013, 09:51 AM #20
My apologies for the late reply.
The testo 552 Vacuum Gauge is brand new to the market. Unlike most vacuum gauges that use a Pirani thermistor sensor, the t552 is using an absolute pressure sensor. By incorporating this type of sensor, we are able to achieve very good accuracy of +/- 10 microns down to 10 microns, but even better is the resiliency of the sensor, which requires no cleaning, nor is subject to contamination from oil. As stated in our advertises, there are other nice features like drop tested to 6', high limit alarm, ambient temp sensor to calculate evaporation temperature of water, and as you've picked up on it can be connected to a testo 570 Manifold save and print evacuation date. Distribution is bringing in inventory, so you should start to see them at your local wholesaler or internet reseller.
04-01-2013, 10:36 AM #21
- Jan 2013
- 969
IT CONNECTS TO THE 570???? How did I miss that?????
I just couldn't get passed the the 72 PSI over pressure limitation. Guess I got disillusioned and quit reading before I reached the text on the compatibility of the printer hook up.
Gonna have to rethink this one...ok...I thought about it. Gonna get one
04-03-2013, 05:29 PM #22
- Jan 2013
- 969
Got mine today and it's as sturdy as a brick out-house!
Screen is like an SMAN 4....Big ass numerals.
Gonna break the cherry when I insall the 16 seer two sate ac for the family business....using my 570 with vacuum rated hoses.....I ani't in a hurry to finish this one.
HEY JP!!!!
04-07-2013, 10:15 PM #23
Didn't want to dig up some old threads on core tools but I'm not so sure there is anything wrong with this gauge.
Looks like it works good actually“If You Can Dodge A Wrench You Can Dodge A Ball”
04-07-2013, 10:20 PM #24
I have gotten my hands on one of these.
I plan on doing a few tests with it. One on which will be to compare it to the Bluvac. I will post results.
04-07-2013, 11:18 PM #25
- Jan 2013
- 969
04-07-2013, 11:33 PM #26
