Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 65
  1. #40
    Quote Originally Posted by crackertech View Post
    But there better junk.
    Meh...
    Not so sure...
    Gimme 20 year old RLs and I'll make 'em purr.
    I don't think that the new HP cases will even be standing after 20 years.
  2. #41
    florida
    Meh...
    Not so sure...
    I don't think any new case will last 20 years.And what was HP thinging going back to 120 vac on the defrost term?
    Educational forums are open.
  3. #42
    They're doing some goofy stuff with defrost.
    Have you seen the individual case termination setups, yet?
    Not complicated IF you understand how defrost works, but I had an afternoon's enjoyment watching a tech from another company who DIDN'T understand try to work it out.
  4. #43
    Dec 2006
    In a Mess
    you talkin about the high heat limit klixon wired to the coils of a couple relays that switch the load side of an electric defrost with the load wires and control wires with cheap push on sta-kons that are not that tight and with moving the electrical panel its easy for them to come off and this is noticed on a Friday night at 9pm when the case is iced up because there was no heater?
    you mean those ones??
    hahaha
    Sig removed by mod. G-Rated site
  5. #44
    florida
    Quote Originally Posted by MikeySq View Post
    hahaha
    Yep.
  6. #45
    florida
    Yes I have a bunch of them.
  7. #46
    Normally open solenoid in the dump line for hot gas defrost.
    Then, in their eminent wisdom, they wire them wrong....
  8. #47
    florida
    So you know what I'm talking about. HP.
  9. #48
    Jun 2001
    Michigan
    it's not that bad. start up guy should be getting that stuff tight. I actually like the set up.
  10. #49
    Quote Originally Posted by Dowadudda View Post
    Exactly.
  11. #50
    Jun 2001
    Michigan
    JP, bear in mind buddy, I now again work for an HP Dealer. I am just practicing my lines.
    HP is GGGRRRREAT.
  12. #51
    HP is GGGRRRREAT.
    We install a ton of that stuff, too.
    I've never been told that we're an "HP dealer"
    I speak politically to the customers, but I'll speak my mind elsewhere.
  13. #52
    florida
    We had a start up guy wire the beldan cable to the hot side if that relay, Lot's of toasted boards that morning at start up.
Tags for this Thread
