Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 65
  1. #27
    California
    The liquid injection isn't for capacity control.
    The liquid injection is for de-superheating.
  2. #28
    Dec 2006
    In a Mess
    If you're running Low Temp R-22, you might regret that decision this summer....
    I have a feeling I know the customer TDC is working with and they have chosen to go with R407a on all their new installs. Ya know its better for the environment! haha
    Sig removed by mod. G-Rated site
  3. #29
    Dec 2006
    In a Mess
    Quote Originally Posted by Phase Loss View Post
    I also Agree, again Bitzer must have specified this for R407a, They also use it for the LT Copeland scrolls!
    These guys used to be big on the Economized Cool vapor injection but i guess that was in the old days of R404a haha!
  4. #30
    Mar 2013
    Toronto
    i agree its not capacity control but when your unloaded your raising your suction pressure so your compression ration should be ok and you dont have to worry about liquid injection to cool the heads of your compressor. its a 407A rack and the worry is its flooding and leading to major problems in the compressor. the system doesnt have an accumulator.
    a heater would work but i dont have any power available at my case. id have to run a new feed and a breaker
  5. #31
    Dec 2006
    In a Mess
    Quote Originally Posted by TopDeadCenter View Post
    You may want to re think that one
    back to the original problem of this post, keep those coils from icing, make sure your TX is clear and you wont flood, You may want to look closely at your TXV's and seeper than the element and make sure the port is OK, unless the proper TX port is in there the OEM port/valve was most-likely for 404a and that will cause flooding just a hunch but a good spot to look, Look at your Hussmann Original Serial/data sticker check superheat range then check it again, if ya got digitak gagues this is where you wantto ues them dial and a PT chard may not be quick enough
    A heater for What??
    Are you talking Pan Heater? as a Huss RL case has a pan heater??
    while you are in there amke sure your defrost heaters are all up to snuff as per huss specs
  6. #32
    Mar 2013
    Toronto
    the TXV valves are r22 low temp valves. but the superheats is good. the issue is during my defrost. im not icing up in my coil and my case temp is rising above 55 during my defrost, and all my heaters are working. what i ment by adding a heater was to the lip of the plenum underneath the fans maybe something like a trace heater to stop the possible fllash freezing when it makes contact with the plenums lip.
  7. #33
    Dec 2006
    In a Mess
    the TXV valves are r22 low temp valves. .
    Valves are not Low or Med or High temp, power elements are, verify your valve port, I have seen a refrigerant conversion before with a SZ/VZ swap but that's not gonna cut it on a 404a sized port..... just a thought[fyi this is a spoorlan biased statement, haha]
    How good? whats your Swing?
    the issue is during my defrost. im not icing up in my coil and my case temp is rising above 55 during my defrost, and all my heaters are working. .
    is your Termination working?
    Juskt keep in Mind that there are Thousands and thousands if not Millions of Hussmann RL cases out there and make sure you have all points covered before redesign is required, for example if a case is not set 100% properly you may have issues
    Just ideas!
  8. #34
    Quote Originally Posted by MikeySq View Post
    Just ideas!
    Adding to what Mikey has said. I've seen cases where even a subcooler being improperly accounted for during sizing will prevent proper performance.
    R404a valves require a larger port, typically, than a 22 valve will.
    Also, think hard about the last thing that he said. There are millions of these cases out there and there is no reason that you should have to start modifying these couple.
  9. #35
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by Dowadudda View Post
    Little do you know your find was not the first who found it.
    Interesting how a coworker can know something, and know there is another crew tasked to complete the job the original coworker fell short on - yet be too self absorbed to mention anything about it at the time.....or recollect his original findings when calling me several months later to ask details about the issue as this coworker thought maybe the same thing was happening at another store.
    But ya talk a good game anyway - you definitely have that working in your favor.
    "The problem is the average person isn’t tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and it’s not in the movies they watch, and it’s not in the few books that they buy, they don’t get it" - Jack Canfield
  10. #36
    Jun 2001
    Michigan
    your first sentence is untrue. the second sentence was about pacifying you.
    the second statement is accurate. I talk a great game.
  11. #37
    florida
    Ya'll can solve the problem by replacing that Hussman case with a HP case.
    Educational forums are open.
  12. #38
    Quote Originally Posted by crackertech View Post
    HP = Huge Problems.
    They're junk, too.
  13. #39
    florida
    HP = Huge Problems.
    They're junk, too.
    But there better junk.
Tags for this Thread
