Results 1 to 13 of 16
    Dec 2009
    Questions regarding water cooled A/C and high water bills
    Hi there!
    I want your recommendation on reducing a water bill at a factory I service.
    They currently have 45-50 water cooled units totaling approximately 1700 tonnes of cooling. In the summer the equipment runs almost 24/7 I have done done some preliminary figures and estimate they use 5000 GPM!!!!!!!!!
    Most units are Comfort-Aire M# WPC-120-5 and WPC-60-5 (10 tonne 575 V) and (5 tonne 575 V)
    Switching the units to air cooled is NOT an option. Temperatures in the plant range from 70F in the winter to 120F in the summer.
    I maintain and check the water regulating valves each spring and like to set them for 100F condensing.
    I am not against pricing out a closed loop system but I don't have alot of experience in that area. I dont think a cooling tower alone would work because I would like to aim for 60-65F inlet and will have 90-110F outlet.
    IDEAS????
    Any information or help would be appreciated.
    I work in south eastern Ontario to give you an idea of weather conditions.
    Jul 2012
    Western KY
    Cooling tower!! Don't need 60-65 water.
    Jul 2011
    Croatia
    hi, ginger, i assume you mistakenly changed what you specify as inlet and outlet, cooling tower should lower temperature, not raise it.
    your case seems to be typical case which actually calls for cooling towers. condensing temperature on chiller side should be as low as possible, that will only increase chiller efficiency.
    could you be specific on what do you think is a problem with that?
    Oct 2010
    Ontario doesn't get below 70F in winter? Cooling towers is my vote. You're using waste water now?
    Anytown USA
    Cooling tower and acid clean the condenser bundles..
    Dec 2009
    Quote Originally Posted by Drazen View Post
    I was referring to the inlet and outlet temps of the A/C units.
    Dec 2009
    Quote Originally Posted by jtrammel View Post
    The temperature in the plant does not go below 70F in the winter. Right now they are using city water. Very expensive!
    Dec 2009
    Quote Originally Posted by Tommy knocker View Post
    Optimal temperature for water cooled units is 65F inlet (as per Comfort-Aire specs)
    Dec 2009
    Someone asked why I thought a cooling tower was the wrong choice.
    I have very little experience with these so correct me if I am wrong. Wouldnt a cooling tower have to be MASSIVE to reduce the water temperature from 100F to 70F (I would prefer 60-65 however someone else had mentioned that 65F was to cold) especially at 1700 tonnes of cooling inside the plant?
    East of big city prices.
    Yep sounds like a pump and dump system to me .
    45-50 units mostly 10 tons that's 500 tons in my mind where are you getting 1700 tonnes?
    I may be wrong but it's either tons or Kw's not tonnes.
    Mar 2010
    Morgan Hill Ca.
    If it were mine, without seeing this set up, I would install a couple small cooling towers. Your math is whack..
    I come up with 1000 GPM at a worse case scenario of 12*F temp split and 500 tons of cooling.
    This would equate to a worst case of two 250 towers... (These are itty bitty)....
    Double check your math against an equipment list and get back to this thread... I'm thinking this job scope would have a stupid fast return on investment.
    GT
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
    Dec 2009
    Quote Originally Posted by GT Jets View Post
    GT
    Im using Comfort Aire spec. With 1700 tonnes of cooling when the water is @ 70F the units use 1.35 GPM/ per tonne.
    1.35GPM x 1700 tonnes = 2295 GPM
    You were right to correct me on the GPM. The units use 3 GPM @ and inlet temperature of 85F
    However 2295 GPM is still a heck of alot of water.
    Thanks again for your help.
    Keep in mind this is a fairly large plant with 45 -50 units. Is it even possible to run the supply and return lines that far? I suppose I would just increase the size of the pumps?
