Page 1 of 7 1234567 LastLast
Results 1 to 13 of 81
    Aug 2012
    Iraq
    paint thinner in purging air conditioning pipes
    its possible to purge the ac unit pipes with paint thinner
    i use it to clean the evaporator of window type ac
    so it cleaned it from oils and other contaminant
    so what advantage and disadvantage
    There are many chemicals used as paint thinner, which specific chemical/product are you looking at?
    I wouldn't use anything marketed as a paint thinner for flushing the refrigerant cycle of an AC system.
    There could be components of it that will leave harmful residue in the system, and the moisture content may be unacceptable.
    Aug 2012
    Iraq
    so what solvent you use to flush the ac system
    Virginia
    unless the lines are contaminated from a burn out just blow them out with nitrogen
    Go Trump
    moved to tech to tech
    Paint thinner sounds like a terrible idea. In the old days we used R-11 as a flushing solvent but that is no longer legal, and incredibly expensive if available at all. There is a product called RX-11 that can be used if you need something more than a nitrogen flush. Google RX-11 and it comes right up.
    Sterling Heights, MI
    RX-11 is non-flammable but paint thinner is flammable. RX-11 is also approved for the use, while I would guess paint thinner is not, nor would it probably be compatable with system components. While you may not have this product readily available where you are, using paint thinner is probably not a good idea from a warranty point of view.
    Better Service Through Knowledge...
    RSES, The HVACR Training Authority. www.rses.org
    UWUA Local 223
    Aug 2012
    Iraq
    Quote Originally Posted by catmanacman View Post
    thanx
    Aug 2012
    Iraq
    Quote Originally Posted by tchntch View Post
    thanx
    some instruction about how to use it
    Aug 2012
    Iraq
    Quote Originally Posted by rfhcms View Post
    can you explain more
    Jun 2011
    New Braunfels, TX
    I've heard of one AC company using Naptha as a solvent to clean the lines, but they had to be very careful to get the pure stuff because many brands have oils in them. I recently heard that they are using Coleman fuel on rag rolls shot thru the suction line with CO2 to wipe/clean the gunk out, then they do a final flush of RX-11,
    All this work to "save" on the RX-11 cost, but the labor goes thru the roof!
    Chicago IL
    "Rag rolls"?
    I've never heard that. Sounds like a potential nightmare
    Jan 2013
    Henderson, NV
    We had a rep from Lennox in the other day, and any trace elements of Rx-11 in an under warranty compressor will void the warranty.
    He said the engineers now say to use R-22 to flush linesets. Even on 410a systems.
